WARM START - I hate my Porsche 911 Carrera 4S
Old 03-03-2015, 03:22 PM
  #31
gota911
Newbies Hospitality Director
gota911's Avatar
Originally Posted by DC911S
He's in the UK......ground wires as we Yanks say. Eraser=Rubber, Boot=Trunk, Bonnet=Hood.....and they still spell tire and color wrong too.
same for color!
Old 03-03-2015, 10:36 PM
  #32
stronbl
stronbl's Avatar
Originally Posted by mattblack
I had my Porsche 911 Carrera 4S for 4 years now and spent a fortune trying to get the warm start fixed. 28,000 miles on the clock
Problem..
Car fires up on cold start - Great Smile
Warm start say I drive for 10 mins park up and then restart its struggling like mad to startup, so bloody embarrassing pulling up in a flash car that sounds like a coughing dog when starting up.. wrrr wrror worrr worrr worr then starts and sometimes I have to turn car off then try again in 5 mins
These are the actions I have had done in order to get this fixed and failed.
1. Part number 997-607-019-03 ("alternator/starter harness", "alternator/starter cable loom")
All the below done by a indy
2. Battery Earth Cables and 996 607 030 00 ground strap
3. New Battery
4. Coil packs
5. New Starter Motor 2 months ago (helped for 1 week and problems back)
I just want to enjoy this 911 for the first time before my finance is fully paid...
Matt
When I read your symptoms I immediately thought of the starter-ground-cable system, but you had that replaced. I'd still test voltage as noted others as there could be a ground issue. Also as suggested, the fuel pump could be an issue.
I had a '73 that had the same symptoms, great cold, and then hot it would die, or just poke along at only very low revs. Give it gas and it shuts down. I could always start it but could not go faster than 10 mph roughly. Replaced everything, including fuel pump, filters etc. Eventually it was bad voltage regulation. It would heat up and short out, interrupting the spark.
That was then, this is now, for today I'd start with your DME control unit. PIWIS can test it for codes, probably Durametric too. But I'd go with PIWIS as you could try to reprogram it; but I'd be inclined to replace it - if it's bad it will be bad after reprogramming too. A replacement unit will have to be reprogramed by PIWIS (maybe Durametric can reprogram it but I don't know).
Alternatively you may wish to investigate the condition of your coil packs. Unless they are really cracked or otherwise fouled-up, they should not be the problem, but might as well rule them out too.
Unfortunately you've got yourself a "process of elimination" job in front of you. Good luck !
Old 03-03-2015, 11:48 PM
  #33
PrimeMvr
PrimeMvr's Avatar
mattblack, can you clarify the issue? When it dies and you attempt to restart, is it turning over really slowly, or cranking fine but not firing?
If it's cranking slowly and you have a manual, put it in neutral. Perhaps your clutch is slightly out of adjustment and dragging at the right temp. If it's PDK or still cranks slowly in neutral, then I still think there is an electrical connection to the starter, not necessarily the ground (earth) that is corroded or loose.
If it's cranking fine but not firing, then my bet is coils or fuel pressure leak down causing a vapor lock. Careful checking fuel pressures on these cars, as it's a bit higher than most pickup trucks.
Old 03-04-2015, 12:04 AM
  #34
StormRune
StormRune's Avatar
Great note on the fuel pressure check. That is something you should probably only attempt with care on 997.1 cars, which OP's car appears to be judging from the front end lighting. On the 997.2 models, it is probably best to leave the testing to the pros due to the very high pressures used for DFI.
Old 03-04-2015, 04:22 AM
  #35
mattblack
mattblack's Avatar
like starting a car with a battery thats about to die only when hot..
I will try the neutral thing today...
Old 03-04-2015, 04:23 AM
  #36
mattblack
mattblack's Avatar
Amazing info mate :-) what a star..
I will pass this onto the indy today
Old 03-04-2015, 04:24 AM
  #37
mattblack
mattblack's Avatar
Im dropping the car off at the indy today, he has also read this post :-)
Thanks for all your help guys.. I will update you all soon..
Matt
Old 03-04-2015, 07:26 AM
  #38
McCulla
McCulla's Avatar
Maybe in the context of this thread this question is already answered...but
IIRC the PWIWS updates are really pricey, your indy may not be equipped with this(?) Did you mention if you indy has this software available? I'm no tech but as it has been mentioned here, the OBD stuff may not be enough info. (For what it's worth, I had my indy chase a CEL (literally!!) for nearly 4 years. I feel your pain.)
Old 03-04-2015, 11:28 AM
  #39
StormRune
StormRune's Avatar
Based upon the detail you provided here I'll retract my suggestion of the fuel pressure leakdown. When that occurs, the starter turns the engine over at a normal speed but it just won't fire. In your case, it sounds like the starter is barely able to get the engine to turn.
Old 03-04-2015, 05:48 PM
  #40
motopix
motopix's Avatar
There was a another thread on here and it turned out to be the starter. In the other thread, changing ground wires didn't help either.
I have the same symptoms but also have a dodgy battery. I plan to replace the battery this weekend but am expecting to replace the starter shortly thereafter.
Old 03-05-2015, 02:11 AM
  #41
cali_banks
cali_banks's Avatar
Its funny, mine has the same problem...i disconnected the neg and clean off the corrosion...car cranked like a champ for a day , then went back it cranking like the battery was dying.
Old 03-05-2015, 02:52 PM
  #42
Spoddle
Spoddle's Avatar
Could a bad alternator cause this issue? I'm guessing this could be tested with a volt meter to rule it out.
Old 03-05-2015, 10:22 PM
  #43
PJorgen
PJorgen's Avatar
Default Coolant temp sensor?
Doesn't really fit with your symptoms, but since we're throwing out ideas here...
Had this issue with both of my Audis. If the coolant temperature sensor is faulty, the computer can't calculate the correct air/fuel mixture for a hot engine and it becomes very hard to start.
Worth trying if nothing else works.
Old 03-06-2015, 01:14 AM
  #44
jdjones2010
jdjones2010's Avatar
I KNOW how you Feel Mate! 99% of the time THESE Cars are NEVER that Simple! GL & let us know what you end up finding out!
Old 03-06-2015, 01:17 AM
  #45
jdjones2010
Unless this is your Everyday Driver just put a Battery Tender on it & you won't have to Worry about that! Finding the Problem will be a WHOLE Nuther' Matter! GL!
Quick Reply: WARM START - I hate my Porsche 911 Carrera 4S
