Paint scratch repair
Looks like the wife's purse got me. For rock chips, I've used the Langka product over the years with great success. However, for a scratch like this, doubt it'll work as well. BTW, it's about 4" long, and is right below the left side rear window.
Recommendations other than a full repaint?
P.S. I haven't forgotten about your 2nd key...
Dr. Colorchip will fill in rock chips but it is an iterative process and will require letting each thin layer dry, then clean off the surrounding areas and re-apply/ dry / clean a number of times building up he paint. Practice and you shall be rewarded...
Does your finger nail catch on the scratch? That will tell you how deep it is and whether it could be polished out.
Always best to try the least aggressive approach first.
Dr. Colorchip will fill in rock chips but it is an iterative process and will require letting each thin layer dry, then clean off the surrounding areas and re-apply/ dry / clean a number of times building up he paint. Practice and you shall be rewarded...[/QUOTE]
Thanks for advice. I'll definitely try it.
Let me throw in my 2 cents worth.
Someone asked but I don't see the specific answer - Does the scratch catch the back of your fingernail? I know you've tried some cleaner that you have but that entire panel is covered with micro scratches that would completely disappear with a polish.
Dr. Colorchip will not be a very food repair for that panel that catches the light like that. You are at best looking at a 60-65 percent repair of original. I did a scratch like that with Dr Colorchip behind my rear wheel as the car got hit with an oil pan. Even that low to the ground, with a panel that doesn't reflect light because of the angle, I can see the repair from at least 10 feet away.
Back to my other comment. Do you have a good buffer and decent polish? From your picture(and it might be taken before you polished it) that panel does not look like it's been polished at all.
+1 ...cleaner and wax will not help. You need an abrasive such as a cutting compound and polish. Even if the scratch has some depth to it you can soften it and reduce the effect with a good compound and polish.
Below is an example of what you can eliminate with a good compound (zoom in for better detail - right hand side is untreated, left hand side done with BlackFire SRC compound which is a mild cutting compound. I understand your scratch may be deeper, but there are stronger compounds out there also.
Take a look at forums like autoggek and autopia which are great resources for detaining and dealing with these issues.
If it's not deep a polish will knock it out. You might want to get a professional to look at it if you don't have all the right tools. Personally for something that nasty I wouldn't try it without a paint gauge. I'm not a pro I just polish my own cars and I have a paint gauge for that purpose. From the picture only the depth of that scratch doesn't look like it goes to deep. I'm hoping you have a good 5-6 mils of paint on that panel and it can be polished out.
Just take the pics of why you're doing the repaint (scratches) and then just make sure it's done right...
Fear of getting panels painted for chips or scratches is plain silly, so long as the outcome is professional grade.
