997.1 - P0441 Code - Fuel tank ventilation system: Below Limit
Old 07-14-2015, 01:05 AM
Musclehedz101
Musclehedz101's Avatar
Question 997.1 - P0441 Code - Fuel tank ventilation system: Below Limit
Coming to the collective for some guidance on this one...
I did a few searches and found other posts with the P0441 code but were all pertaining to the Cayenne or Boxter. I have 07' 997.1 C4S and it is throwing this code. Here is what the Durametric Tool shows.
No rough starts
No slow starts
No Whistle sounds
Tried resetting but code came back after 1-2 days.
Have a new gas cap on order as a lost cost first attempt at resolution...
Any suggestions/thoughts?
Thanks in advance.
Old 12-24-2015, 11:02 PM
Edcantera
Edcantera's Avatar
Did you ever find the cause? I've had this code pop up a few times. Cleared it and it stayed away for a while then popped up again a few days ago.
Old 12-25-2015, 08:11 PM
user 72902
user 72902's Avatar
Do you think you need your Vapor Canister Filter for Carbon Canister replaced? Part # 997-201-501-00-M100
Old 12-26-2015, 09:45 AM
Rikky001
Rikky001's Avatar
Did you check your gas cap? Is it sealing properly?
Old 12-26-2015, 01:53 PM
Bruce In Philly
Bruce In Philly's Avatar
Received 1,424 Likes on 864 Posts
I had a faulty/worn gas cap and it was ID'd with a Durametric read:
'5504 Tank System Leak" FWIW. New cap and no return light.
Peace
Bruce in Philly
Quick Reply: 997.1 - P0441 Code - Fuel tank ventilation system: Below Limit
