Damned AC buttons-- a fix???
Old 01-09-2017, 12:33 PM
ric-ko
ric-ko's Avatar
Default Damned AC buttons-- a fix???
Hi folks-- I am not affiliated with these guys-- but just got an email that they are building buttons:
http://www.climarepair.com/porsche-r...rce=newsletter
VERY FREAKING COOL! Hope they are out soon.
Old 01-09-2017, 12:36 PM
ChicagoSpeed996
ChicagoSpeed996's Avatar
Wow, looks like a great product for an eyesore of a problem!
Old 01-09-2017, 01:00 PM
ric-ko
ric-ko's Avatar
Bought some-- looks like they come out Feb 1
Old 01-09-2017, 01:07 PM
yvesvidal
yvesvidal's Avatar
Freaking expensive for two pieces of injected plastic.
Yves
Old 01-09-2017, 01:09 PM
mickfluff
mickfluff's Avatar
99 is for both switches correct as it gives you the option of "1" for 99$... one means a pair of two correct?
also read removing these buttons is not a simple DIY as they suggest... anyone do it?
Old 01-09-2017, 01:20 PM
Sneaky Pete
Sneaky Pete's Avatar
I would say yes. I just ordered some.....hopefully they developed a removal tool.
Old 01-09-2017, 02:04 PM
jeffm
jeffm's Avatar
For 99 bucks and free shipping....ordered!
Thanks for the heads up.
Old 01-09-2017, 02:30 PM
911searcher
911searcher's Avatar
Ordered.
$134.84 CAD ($1.00 CAD = $0.73423138 USD)
Your order number is: 1187
They have an older model too it seems.
http://www.climarepair.com/porsche-p...r-kit-english/
$34.99
Old 01-09-2017, 02:32 PM
911searcher
'After 2 years of research climarepair.com is proud to announce to be the first and only seller of replacement buttons for your Porsche Carrera Boxster and Cayman air condition unit worldwide."
What's a Carrera Boxster ?
If I like the button replacements, I'll get some caps
http://www.climarepair.com/porsche-wheel-center-caps/
Old 01-09-2017, 02:44 PM
Ni_Mo
Ni_Mo's Avatar
I just did it to get the ac panel painted piano black, it is real easy to remove.
Old 01-09-2017, 02:57 PM
Ni_Mo
Ni_Mo's Avatar
Ordered too
Removal:
Install:
Old 01-09-2017, 03:10 PM
Sneaky Pete
Can you explain how to remove the ac panel?
Greg Navarro (02-29-2020)
Old 01-09-2017, 03:18 PM
Ni_Mo
Ni_Mo's Avatar
Sure, the easiest way is to follow this by tye:
https://rennlist.com/forums/diy-subm...e-removal.html
Then to remove the ac panel there are 2 tabs which you need to push in L&R side and then the panel just slides out, disconnect & away you go.
Old 01-09-2017, 03:20 PM
mickfluff
mickfluff's Avatar
delete
Old 01-09-2017, 03:25 PM
jeffm
jeffm's Avatar
wow is in fact 99 per button so 198 for both....
It's $99 for the pair. This is a pretty good deal as Sticky No More charges $150 and require a core return IIRC.
I painted mine all black with plasti-dip and it looks decent. But for this pricee it's an easy, permanent and affordable solution.
Quick Reply: Damned AC buttons-- a fix???
