997 GT2/GT3 Forum 2005-2012
fellow auto-xers what front camber are you running?
Old 07-08-2019, 10:02 AM
noro
noro's Avatar
Default fellow auto-xers what front camber are you running?
Like the title says... I am roughly at -2.3 degrees, is that not aggressive enough? Car is nearly stock suspension-wise.
Old 07-08-2019, 03:07 PM
balefire
balefire's Avatar
Last I checked, front -2.9, rear -2.5.
Also stock suspension.
Lowest ride height
More camber was possible but tire temps did not dictate it was needed.
Old 07-08-2019, 05:12 PM
Auto_Werks 3.6
Quit Smokin'
Auto_Werks 3.6's Avatar
I'm at about -2.2* front and rear. It's hard on the inside edge on the street, and a little hard on the outside edge at autocross. It definitely seems like it would tolerate some more camber if it was track only.
Old 07-09-2019, 10:21 PM
Drew_K
Drew_K's Avatar
I run 2.5 up front and tire wear is pretty reasonable. I used to have 3.5 and the inside edges would cord in less than 1000 miles. I’m not doing that again.
Old 07-10-2019, 01:26 AM
balefire
balefire's Avatar
Braking could be better with my aggressive camber.
So it's a trade off obviously.
I've contemplated taking my front camber down a smidge.
Old 06-01-2020, 08:53 AM
blade7
blade7's Avatar
Wrong thread.
Quick Reply: fellow auto-xers what front camber are you running?
