Power Steering Leak on Passenger Side Source?
You can buy the Pentosin fluid at Autozone, and top it off. BTW, checking the level is weird, I've seen different directions on how to do it. Crank the engine cold, shut it off and you have about 20-30 seconds to check the dipstick and it should hit the Cold mark. But I've also seen other directions, and I believe it's the same with hot engine. Shut it off and in 20 seconds get a dipstick reading for hot level. I'll try to look for it and post a screen shot. The problem is other 911s have a different system than the GT3 and probably different instructions on taking a reading(Turbo, Carrera, Carrera S,etc) So you obviously don't want to be overfilled or under.
But do rinse it off asap, and don't let it hit paint. I would then run the engine and see if it's a very slow drip or worse-
What year is your car?
When mine leaked, it was exactly on the same parts you showed in your initial photo. I don’t remember if I saw anything coming from the hoses. I only saw the soiled parts and hydraulic fluid in the ground. A shop had just worked on my car with the motor out so I took it back there. They found it to be one of those hoses slowly leaking.
If you read the detailed screenshot I posted before, the .1 cars from 26 June 2007 have the Variant 2 setup(hopefully that's the case for you. Otherwise upgrade to the Variant 2 as soon as you can(now since you stated you'll take the car to be serviced)
Here is the part about the Variant 1, before June 26 2007 cars. The nightmare here is if the axial play is beyond the limit, the pressure hose number 6 must be replaced, and that means dropping engine and transmission. Hopefully not your case
Continued:
So hopefully if your axial play is acceptable, have the Variant 2 installed even if this is not the part leaking. If the play is beyond limit, it says to replace hose 6 and as mentioned that involves dropping the engine and transmission. So I'd say owners with Variant 1 should upgrade to Variant2 asap even if you have no leaks, before axial play exceeds the limit-
Also, see if it's possible to change the title on this thread to Hydraulic leak or power steering leak instead of coolant since it appears to be the case, it will make it easier to find if someone is searching-
So I knew I had read before that someone had replaced hose number 6 without dropping the engine and transmission. Pretty clever, so here's the link-but in his case it looks like he kept Variant1 and I might post on his thread a reference to this one, since Variant 2 should be installed:
https://rennlist.com/forums/997-gt2-...e-997-gt3.html
I'm not 100% positive of the fluid. I assumed coolant because of the greenish hue to it. Is there an easy way to know? I did take it around the block before really looking into it and didn't notice any abnormalities in driving or steering? The coolant lines are pinned if that would make a difference?
Continued:
The Rebel
Want to never have this problem again and “gain” horsepower whilst losing weight in the back, and better distributing whatever weight is left?
Put a Porsche Motorsport, electric-powered, hydraulic, power steering pump in the front. PM me if you need help.
Your receipt says "R&I engine and transmission assembly" so it looks like they removed and installed engine and trans to replace the entire hose number 6. So hopefully it doesn't have to be replaced again
I would assume they put in the Variant 2 coupler and you could just compare to the screenshots I posted.
Hey folks, so that is 99% pentosin leaking from the PS reservoir or one of the lines. Its common at the press to fit line on the right side of the reservoir. Have it looked at. here's the problem. The lines are long and you have to drop motor to replace. Some have cut the lines and joined them with a union to keep from having to drop motor. That's why the labor is high. I went through this a couple years ago...
The other issue, pentosin is highly flammable. Secondly it will cause those rubber seals and gaskets to swell (the ones down by your water jacket connections).
So get it fixed. You may need to replace the seals down low depending how long it's been seeping.
