997 GT2/GT3 Forum 2005-2012
997.2 GT3 spark plug choices?
Old 05-31-2023, 01:36 PM
  #61
JB911
JB911's Avatar
Get the NGKs-and as mentioned, they have a platinum version too. And the insane racing plug which can be bought from FVD if money is no object-
https://www.fvd.net/ch-en/9916022018...otorsport.html
https://demonspeed.com/product/spark...1-gt3-and-cup/
I then searched for BMW E36 (they used the same extinct Bosch plugs as 997 GT3s)racing spark plugs, since the Cup part number is a Porsche part number-it seems I found it-but a word of caution-if you search for R2348-10 you can get a dubious result from some shops.
For instance, rock auto seems to have them, but the picture they use is wrong, and they only have 4 in stock. But they might be able to order more, if it's just the wrong picture but correct plug:
https://www.rockauto.com/en/moreinfo.php?pk=69979&jsn=7
The correct one is listed below, it is a surface electrode plug, no protruding negative electrode at all. It looks like it is indeed the one listed for Cup cars up to 2017. The Porsche part number at FVD and Demonspeed say "991" but up to 2017 those cup cars used the 997 Mezger engine.
So these are the links for NGK racing plugs. I did see an eBay vendor selling direct from Japan, but the shipping was pretty steep.
Finding these through "vehicle fitment" search will not yield any results, because it's competition only-
$42.46 each, so less than half the price than the few places that sell them:
https://www.ngk.com/ngk-6839-r2349-10-racing-plug
https://www.sparkplugs.com/ngk-6839-...10-racing-plug
JB
andrewgt3 (06-01-2023)
Old 05-31-2023, 11:23 PM
  #62
JB911
JB911's Avatar
I did some more searching for the Racing plug- Only FVD, Demonspeed and Auto Atlanta list the Cup/Mezger/Motorsports NGK,
part # 991 602 201 8A
As posted, on the NGK website, the R2349 plugs are available-the heat ranges are 9,10 and 11
But the only heat range available is 10, (9 and 11 have been discontinued). These plugs would be used in screaming conditions, so people tracking their cars would probably benefit from using them-maybe the heat range is too cold for street use-
https://www.ngk.com/search/all?q=R2349
Old 06-01-2023, 08:12 AM
  #63
JG 996T
JG 996T's Avatar
i used the ngk R two years ago. runs great. is the interval every 2 or 4 years?
Old 06-01-2023, 11:49 AM
  #64
Ed@Demonspeed
Basic Sponsor
Ed@Demonspeed's Avatar
So, the 9916022018A, which is for the Mezger version of the 991 cup, is the heat range 11.
Spark Plug | 991 GT3 and Cup | 991.1 - Demon Speed Motorsports
We do also have the Y5DDC's.
Spark Plugs 996 Cup / 997 Cup | Bosch Y5DDC - Demon Speed Motorsports
Ed
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
Old 06-01-2023, 11:57 AM
  #65
JB911
JB911's Avatar
Thanks Ed,
I did see in your site's picture of the plug that it was heat range11. NGK says it's been discontinued, but from what I see NGK's heat range 10 and 11 is still a colder plug compared to the OEM Bosch-
For those who want the Y5DDC, there you go, a source that has them 👍
As they disappear, NGK will be a good choice with 3 options-
JB
Old 06-01-2023, 05:39 PM
  #66
JB911
JB911's Avatar
Interval is 4 years-and I did mine not long ago, otherwise I would probably try the Racing plugs. I like the fact it has no ground electrodes-
Lots of members track their cars, it would be interesting to see a used set after some time running-
I will probably try them the next time 👍
JB
Old 06-07-2023, 06:16 PM
  #67
andrewgt3
andrewgt3's Avatar
Installed the DCPR8EKC NGKs (stock number 7168) today with new coil packs on a 2007 997.1 -- Running great.
Thank you all for the info!
The only issue is the gap difference - guess it's not much of an issue? I did not check or re-gap as I didn't see any way to change it on these plugs.
no more bosch...
Old 06-08-2023, 12:17 AM
  #68
JB911
JB911's Avatar
I went on the GT3 Cup section of rennlist where they were talking about the Racing NGK plug(which all Cup cars use)
The discussion died out and these days the heat range 11 has been discontinued. The surface discharge plug's function is to protect the engine and those cars are screaming for hours, a molten electrode would destroy the piston and cylinder.
I couldn't find any info on Cup car plug change intervals, and it's not in the Cup manual either. Anyway, there probably is no advantage using them on a street car-
Old 06-08-2023, 10:15 AM
  #69
Clifton
Clifton's Avatar
Originally Posted by andrewgt3
I've shared with others in the past, but you may want to double check the orientation of your QuickJacks. The large yellow label on each lift is considered to be the "front" and it should be positioned (front/rear) to point to where the bulk of the mass resides. Our cars are so light that it may not really matter, but I have seen QJs struggle to lift the car because of the loading was not incorrect. Also worth noting, if you do flip them around so that the label points to the engine, make sure the mechanical locks are still on the outside of car (like yours is pictured).
Example:
Engine in the front - Label side front
Engine in the rear/mid - Label side rear
Old 06-08-2023, 01:07 PM
  #70
andrewgt3
andrewgt3's Avatar
thanks for the tip!
Old 04-08-2024, 05:45 PM
  #71
jbse39
jbse39's Avatar
I just order a set of NGK plugs from Rockauto, and noticed Rockauto lists plug gap information. Anyone adjust the gap to match the "OE-Recommended Gap"?
Thanks.
Old 04-10-2024, 12:38 PM
  #72
RAudi Driver
RAudi Driver's Avatar
Received 2,755 Likes on 1,649 Posts
I always double check gap.
JpCrp (04-10-2024)
Quick Reply: 997.2 GT3 spark plug choices?
