FS: Tarret rear lower control arms locking plates
hi everyone.
these control arms were lightly used on my 997.2 GT3Description:
Restore proper suspension geometry with this adjustable lower rear control arm. The factory control arm can’t compensate enough when lowering your Porsche 996/997/986/987, leaving you stuck with as much as ½” of toe in. The result is poor handling and rapid tire wear. This kit will provide the additional adjustment needed.
The adjusting link has a left and right hand thread on each end. Rotating the link will increase or decrease the overall length of the arm.
A precision Teflon lined spherical rod end replaces the compliant rubber factory bushing for improved suspension response and feedback, and also reduces toe changes during acceleration and deceleration. The result is improved stability and control.
This bolt on kit will help put an end to continuously needing to realign your 991/996/997/981/718/986/987/993 rear suspension.
The factory adjustment cams slip under heavy loading, resulting in alignment changes. These locking plates replace the problematic cam adjusters, and will precisely and positively lock the inboard end of the toe control arm in place.
$300.00 USD
$300.00 USD
