O2 Sensor Extensions
I have GMG headers, 200 cell GMG cats and a GMG center exhaust. I've been running this setup for about 5 years now. No problem passing smog etc. Occasionally I get an O2 sensor fail code on either side of the engine. It happens maybe once every three hundred miles. Usually it's a cold morning or run through some rain etc. I assume the cats aren't fully up to temp or whatever. It's not a big deal but I find it annoying.
I plan to put an 02 sensor extension in to make the o2 sensor less sensitive and I have a few questions:
1. One sensor will interfere with a bracket. Is it better to use a 45 or 90 degree extension for that one?
2. any recommendations on brand etc?
3. there are some that have a mini cat inside them... is that worth considering? https://www.fvd.net/us-en/FVD111LAMS...ividually.html
1.
1.
1. If you can make it fit with a 45 then a 45, but both should work fine.
2 & #. I like FVD's stuff and that baby cat is the cutest thing in the world.
997_rich (10-13-2022)
1.
1.
I also replaced all o2 sensors while I was at it
I have stock headers, stock catalysts, and Fabspeed straight pipes on my 7.1 GT3.
Before I installed the FVD straight extensions, I was having frequent O2 sensor codes, but after the installation of the extensions, I have not had any problems (touching wood).
I know this doesn't exactly help answer your question, but it is proof that the basic concept of the extension works as needed.
Enjoy!
Enjoy!
997_rich (10-17-2022)
There are two types, o2 extenders and then cat extensions for o2 sensors.
One just adds space and in theory more oxygen between the sensor and the manifold. The other actually puts a tiny little cat in between.
Pelican parts has one here
https://www.pelicanparts.com/More_In...yABEgJoifD_BwE
a little less $ than fabspeeds, however these are all Chinese OEM so you can find your own on Alibaba and test them before spending all that $$. Infact the ones I found were an exact replica of Fabspeeds.
https://m.aliexpress.us/item/3256803...ed3f0698f63dcd
https://m.aliexpress.us/item/2255799...f-b16ad7e97abe
I have a pair of Vibrant J-style (90°) spacers I am not using if interested. Like-new condition.
Yes, I too was on the P0430 (and the bank 1 equivalent) bandwagon before installing the O2 sensor extensions.
P0430 Catalyst System Efficiency Below Threshold Bank 2
On my car with aftermarket exhaust I am also getting occasional P0430. But in addition, getting P013, P014, P015 delayed, slow O2 sensor rich to lean bank 2 sensor 2. Has occurred 4 times in the ~4 years I've owned the car. Would you guys feel these codes is worth chasing / fixing?
Thank you.. AS far as I know car is still on original O2 sensors. I'll have to double check records from PO's. No emissions requirements for me though, also happening quite infrequently...
TD
May want to replace them anyway… it’s not just sensing your emission it’s trying to balance your throttle body and fuel. So if you get some weird activity like hesitations on throttle etc it might be good to replace… very easy DIY
