997 GT2/GT3 Forum 2005-2012
RS 3.89 R&P and 6th gear conversion..
Old 02-14-2024, 07:26 PM
  #61
JpCrp
JpCrp's Avatar
Originally Posted by powdrhound
The 4.0 Clutch parts are not $4K. Shop around and you can get the 4.0RS FW/PP/Disc for about $2500. I did the Guard clutch pack when everything was apart.
Ive been browsing a while and haven't seen anything below $3000 even when on sale for a 4.0 rs clutch conversion kit. Or are you talking about piecing the parts together and having it be cheaper?
Old 02-14-2024, 07:32 PM
  #62
Brian Himmelman
Brian Himmelman's Avatar
Originally Posted by christallon
Looking forward to seeing what you choose to do man. I am loving my stock 7.1 RS set-up w 4.0 clutch flywheel, but shifting it to the better ring/pinion and regear takes it up 2 notches. I have not wanted to spend the $'s for this.....yet. Living vicariously through your spend will likely make me jealous, and require my prying the wallet open. Go for it, force my hand please
mine will be done and on the road in a couple months and will give a full opinion for what it is worth
jreifler (02-15-2024)
Old 02-14-2024, 09:14 PM
  #63
powdrhound
powdrhound's Avatar
Received 1,743 Likes on 1,017 Posts
The "kits" are expensive because whoever is selling them has their markup factored in. You can easily purchase the individual parts yourself if you wanna save money.
Old 02-14-2024, 10:28 PM
  #64
Hamhands
Hamhands's Avatar
Got the parts list?
Old 02-14-2024, 10:44 PM
  #65
powdrhound
powdrhound's Avatar
Originally Posted by Hamhands
Got the parts list?
Sure.... Obviously you don't need all those parts if you already have a 3.8RS set up.
997GT3RS 4.0 clutch
964.102.239.81 LWFW
964.114.143.31 Ring gear
928.102.151.01 FW bolts (9x)
931.102.111.02 Pilot bearing
997.116.013.92 Clutch disc
997.116.027.91 Pressure plate
900.067.103.01 Pressure plate bolts (9x)
950.116.813.30 Guide tube
999.270.070.02 Guide tube bolts (2x)
944.116.080.01 Release bearing
997.2GT3RS ring and pinion / 6th gear
997.302.911.90 3.89 (35/9) ring and pinion
997.302.956.90 0.88 6th gear
The following 4 users liked this post by powdrhound:
changster123 (02-15-2024), Hamhands (02-15-2024), LCCHOU (03-04-2024), zweebach (02-23-2024)
Old 02-15-2024, 08:53 AM
  #66
Hamhands
Hamhands's Avatar
997GT3RS 4.0 clutch
964.102.239.81 LWFW
Cheapest I can find the clutch setup alone is $3682.94, part number for the FW bolts has superseded to 928.102.151.02 as well.
$4166 for the r/p and the 6th gear pn says discontinued and I don't see an updated part number for it.
JpCrp (02-15-2024)
Old 02-15-2024, 11:22 PM
  #67
00 Scrub
00 Scrub's Avatar
~$2,000 for the clutch + flywheel from here https://lufteknic.myshopify.com/coll...ant=3138009796
Not sure which PN's they are exactly selling.
Old 02-15-2024, 11:52 PM
  #68
JpCrp
JpCrp's Avatar
Those will be the same equivalent part numbers but they likely aren't oem porsche parts (or OEM porsche supplier parts), changing the pressure plate option to sachs increases the price 50%.
Old 02-16-2024, 01:42 AM
  #69
00 Scrub
00 Scrub's Avatar
Their description says "All New from OE Manufacturers (disc, release bearing, and pressure plate are SACHS)." Seems like it's worth a call to confirm with them.
powdrhound (02-16-2024)
Old 02-16-2024, 01:45 AM
  #70
JpCrp
JpCrp's Avatar
I see now in the description it says pressure plate is sachs, however if you hit the dropdown and select the Sachs pressure plate price goes up to nearly $3000.
I agree, definitely worth a call to clarify.
Old 02-16-2024, 09:55 AM
  #71
jreifler
jreifler's Avatar
997GT3RS 4.0 clutch
964.102.239.81 LWFW
So if you just wanted the FW / Pressure plate and were keeping your existing clutch in an RS car, which of those parts from the Clutch listing would you need ?
Old 02-16-2024, 01:12 PM
  #72
rafter75
rafter75's Avatar
What is the average cost to have a transmission upgraded with the 997.2GT3RS ring and pinion / 6th gear? I know the ring and pinion is around ~$4500 and 6th gear ~$1400. What about labor?
Old 02-16-2024, 06:50 PM
  #73
christallon
christallon's Avatar
All in, I seem to recall it's about $13.5K. That was 3 years ago. Includes parts and labor. Does not include other stuff thy find when in there.
rafter75 (02-16-2024)
Old 02-16-2024, 07:09 PM
  #74
JG 996T
JG 996T's Avatar
kevin @ umw sells a 4 liter clutch kits….reasonable price if recall right
from umw-Kit includes
Sachs Race Engineering 487 Pressure Plate "Bolted"
Genuine Porsche 4.0 Liter GT3RS Clutch Disk
Flywheel , Ring Gear , Pilot Bearing
Pressure Plate Bolts and Flywheel Bolts
Throwout Bearing , Guide Tube , Nylon Bushings
Clutch Lever Shaft Seals , Fork Shaft Bearings
$2,895.00
Old 02-16-2024, 10:03 PM
  #75
rafter75
rafter75's Avatar
With inflation, now it’s probably around $15k! 😂
Quick Reply: RS 3.89 R&P and 6th gear conversion..
