Lemon Law My '07 GT3?--Need Advice
I've had the RMS replaced twice. The car has 2500 miles and was delivered in June 2007. I just picked the car up from service today and drove 30 miles home. The RMS is leaking again. This would be the 3rd RMS replacement. The car has been in the shop for a total of 2 weeks. What should I do? Do I have to have the same Porsche dealer attempt to fix the problem 3 times before I have case for Lemon Law? Should I contact PNA before I take the car back into the dealer? I would appreciate any suggestions. Thank you.
n2cars,
I have returned 2 cars under the lemon law. One golf GTI could not engage 1st gear. One BMW 330 for Xenon lights and other issues they could not repair. As I recall the law stipulates that they have to be unable to repair the same problem at least 3 times (uyou are almost there) or the car has to be kept at the shop for 30 days. VW gave me a very hard time and could not care less as their sale was done! They gave me my money back. BMW fixed the problem very fast and very professionally. They offered to refund my money or to build an identical new car for me. I had a new car made. This allowed me to drive the old car for 3 months and to get the following year model. If they cannot fix your RMS you may end up getting an 08 GT3. Not a bad trade! Let us know what happens.
Good luck,
Stephan
Good luck,
Stephan
This would be a good chance to find out how much PCNA is really committed to customer satisfaction. Get them involved ASAP and see what resolution they propose. No point going legal if you don't have to. The lemon law is always a back-pocket option if all else fails.
For starters, ask to speak with Porsche's regional rep. Your dealer should be able to put you in touch with him/her. Or just contact PCNA directly and go from there.
Good luck with it!
Good luck with it!
I'd try a new dealer if you can. First get in touch with the regional rep and see what he suggests. You're going to need to be firm with these guys as they'll try to shove it to the back burner if they think they can. I'd doubt they'd give you an '08 as they are too scarce. RMS is such a common thing that I don't see why they are having trouble fixing it unless they aren't doing it right or tackling the right area. Let us know how it gets resolved?
GT3 player par excellence
Yea mooty but a GT3 motor is a totally different planet than the C4S motor so it will be interesting to see
how they handle this. I for one would not want another car unless it was the 08.
Monday I will start the 4 step process for "Owner Satisfaction". If Porsche wants to replace the engine is this a reasonable solution to the RMS leak? Will a new engine hurt resale?
This almost makes me wonder if the block has some small issue with its casting so that the RMS just can't lie perfectly flush; hence, the recurrent failures.
Either way my guess is that the next step will be to replace the motor.
Given that there are no indications that your car was abused (i.e. many overrevs on DME scan) and that this leak was a problem from the beginning, I would not think that a new motor would hurt resale. If anything, it could help as it will be a 'lower mileage' engine. In reality, I think there are very few Porsche models ever made that have great resale value...i.e. don't worry about it.
Good Luck! I'm sure this has been a frustrating experience but I think it will end with you enjoying your GT3 like it was new.
The Penguin King
As others have mentioned, I would contact PCNA, explain the experience, and politely request either a new motor or a replacement car. It may take a little time to work through it with them, but I'll bet good money they will have a new motor shipped and installed once you convince them of the problem. On something like a GT3 that will most likely be purchased by a knowledgeable buyer, provided you intend to hold on to it for a while I would not worry about the resale issue.
As others have said it could be some other component that allows the leak and the main seal cannot compensate. I would expect Porsche to replace the engine before they buy your car back under the Lemon Law. Resale value... down a little, because the engine has been removed several times and or replaced.
RMS
I had the RMS leak on my last porsche - '04 C4S. I broke the car in properly and drove it daily - hard. RMS went twice in short time. On third drip on my garage floor - Porsche automatically replaced the engine. I couldn't have been more happy with the service. They were apologetic and very professional about the whole process. Occasionally you will get a block that is slightly out of bore where it matches up with the transmission / intermediate shaft. No big deal. I'd rather know right up front (a couple of thousand miles) that my engine was out of spec, rather than risking a failure out of warranty. Won't hurt resale at all - it's a new engine. Just enjoy!
