997 GT2/GT3 Forum 2005-2012
HELP PLS: Brake Fluid Leak
Old 12-02-2008, 01:43 PM
cannga
cannga's Avatar
Default HELP PLS: Brake Fluid Leak
Hi, am a 997 Turbo owner but asking this question here because of the board's experience.
I've noticed some fluid leak from the left front wheel area of my Turbo: the car would leave a patch on the ground of what looks like hydraulic fluid after I've parked. About three weeks ago I had the one year service at the local Porsche dealer where some "brake cleaner" was listed on the work order. I can't recall if the 2 events are related time wise.
It appears the fluid comes from the luggage compartment (see picture), where the brake fluid reservoir is, and then drips down to the wheel well and the ground. I've looked at the reservoir and the level seems to be ABOVE max -- where the manual says it should be BETWEEN min and max.
I plan to bring the car to the dealer tomorrow, but just a couple of quick questions please:
1. Is it possible the dealer over-filled the brake fluid and I am seeing the spilling from too much brake fluid?
2. Is the brake fluid reservoir supposed to spill like this when over-filled, or is there some abnormal leak in the system?
3. If it is over-filled, is there something that needs to be done?
4. BTW, the oil is also filled so that now all the bars are "lit," I've read about over filling with oil before but don't remember the bottom line. Do I need to do anything?
I would really appreciate your help. Thanks in advance.
Old 12-02-2008, 02:17 PM
carrering
carrering's Avatar
brake fluid is corrosive. if left, it will eat away the paint. take it to the dealership asap and have them clean it up and syphon out the excess fluid. that picture looks like the paint may already be reacting to the fluid. it sounds like it was overfilled.
Old 12-02-2008, 02:21 PM
fc-racer
fc-racer's Avatar
I bet it's related to the unique-to-turbo clutch assist system. When they get faulty, it pressurizes the fluid reservoir. I believe it's a pentosin reservoir, rather than brakefluid but it's been a while since I had the same problem with my 993 turbo.
In my case, it was the slave cylinder and the accumator that had gone bad. Hope this helps.
Old 12-02-2008, 02:53 PM
911/Q45
911/Q45's Avatar
+1 on a bad clutch slave cylinder.
Old 12-03-2008, 07:04 PM
cannga
cannga's Avatar
Thanks everyone for the spot-on replies (really appreciate rennlist's gt3 forum). Following was what I was told today; am not much of a mechanic so if something sounds awefully wrong, it's me, not the Porsche tech who messed up!
Diagnosed as a faulty clutch slave cylinder, that in turn affects the "accumulator," or is it "actuator"?? Ok -- it's something that starts with the letter "a." LOL
The fluid used in the faulty system is Pentosin and I think the tech mentions this system is shared between power steering and clutch assist (???).
Old 12-03-2008, 07:07 PM
GT3 Chuck
GT3 Chuck's Avatar
good to get that fixed...pentosin is highly flammable and has burned a lot of Pcars to the ground
Old 12-03-2008, 07:24 PM
Carrera GT
Wordsmith
Carrera GT's Avatar
Ten years. Same design flaw. Not what I expect from Porsche. I wonder if the accumulator is such a smart solution (I don't have it on mine.) I can't say I've heard of a lot of Pentosin fires, but it's nasty stuff and the various plastic fittings don't inspire confidence.
Old 12-03-2008, 08:48 PM
911/Q45
911/Q45's Avatar
The term is accumulator, it accumulates pressure when the car is running so that power assist is available for a few pumps with the car off. The power steering pump supplies hydraulic pressure for the steering and clutch assists. The reservior up front is for manual operation of the clutch, backed up by the power assist. When the seal in the slave fails, the fluid is pumped through it and overflows the front reservior. Pentosin may be flammable, but it doesn't hurt paint or rubber.
Old 12-04-2008, 02:24 AM
TT Surgeon
TT Surgeon's Avatar
Funny, mine went out today too, dealer found it at my 30k svc. get her back tomorrow.
Quick Reply: HELP PLS: Brake Fluid Leak
