Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 997 GT2/GT3 Forum
Old 04-14-2009, 12:51 AM   #1
porsche52
Board Certified Porsche Trauma Surgeon
Cayenne Grief Counselor
porsche52's Avatar
Default Giro Disc Rotors
I have a GT3 customer who is looking to upgrade his brakes. 08 GT3, 90% track use, approx 5,000 miles. The OEM front rotors are toast, no big surprise. I did some research for him and came across the Giro Disc rotors. They look great in the pics, price is right, does anybody have any feedback or comments about the rotors when used on the track. I would like to set his car up with the Pagid RS 4-4 Orange pads, Giro Disc rotors, titanium heat shields, motul RBF 600 fluid. If anyone is using this setup or has any info/storys that would be great. Thanks in advance
porsche52 is offline   Reply With Quote
Old 04-14-2009, 01:06 AM   #2
fc-racer
Hi there, if I may, I'd recommend going with the Pagid Yellow RS19 or RS29 setup, rather than the RS4-4 Orange. I've used both and find the Yellow has as much friction as the Orange, but is able to stop the car at much lower temps as well. Furthermore, I find the Yellows last longer. There is no downside as far as I can tell to using the Yellows.
In terms of the rotors, the Girodisc does look like a good buy. I recently put a set of DeMan rotors on the car and am very happy with the price point. It's too early to tell on durability, but they appear well built and designed. I had no fade issues on a very brake intensive track this past weekend.
Finally, in terms of the fluid, the Motul RBF600 is excellent. I've never been able to boil it, even when pushing very hard. Some folks prefer the Castrol SRF, but I've found no need to spend the extra dollars. I did 12 track days last year and didn't even bleed the fluid so I'm a big fan of Motul.
Current: Red 997GT3; Previous p-cars: 96 993TT - RUF PSS9, 91 911 Turbo, 89 944 Turbo S
My hillclimb racecar is for sale: www.fcracer.com/talon; Hillclimb video 1; Hillclimb video 2
fc-racer is offline   Reply With Quote
Old 04-14-2009, 04:57 PM   #3
va122
va122's Avatar
The gyro disc are great rotors. They go well with the blacks. RSS has done extensive testing and the pad
operating temps match the rotor.
they are being used by some grand am teams this season.
Victor
Nationally certified PCA instructor.
va122 is offline   Reply With Quote
Old 04-14-2009, 11:01 PM   #4
TripleM
User
TripleM's Avatar
I think best value for money for a two piece floating rotors u can find in the mkt..
Alcons, APs and Brembos are way overpriced..
TripleM is offline   Reply With Quote
Old 04-14-2009, 11:45 PM   #5
James A
User
Has anyone tried the Performance Friction two piece rotors? Another question, for 70% street, 30% track which pads would you go with the RS19 or RS29 Pagid? Or maybe some other pad?
James A is offline   Reply With Quote
Old 04-15-2009, 11:24 AM   #6
FlyingToaster
FlyingToaster's Avatar
I replaced my stock front rotors with PFC two-peice ones on my Cayman, and I can feel a definitive difference in braking performance, I am using Hawk HT-10s. They also saved about 3 lbs per front corner weight. Overall, I am totally satisfied even though they are not cheap.
The only downside is that the initial application of the brake when it is rainy isn't as crisp as the stock rotors, I suspect due to them being solid rotors rather than drilled; so you need to give yourself an extra 1-1.5 sec more time for braking under wet conditions.
FT
VitalMethods
FlyingToaster is offline   Reply With Quote
Old 04-15-2009, 01:20 PM   #7
va122
va122's Avatar
Quote:
The PFC rotors are incompatible with pagids. The pads are the wrong size.
I swear by the PFCs, per their website they last 8x as long as the brembos that last 3x as long as stock. I'm still on mine after 6 months. I got 3 track days out of the stock.
Victor
Old 04-15-2009, 05:31 PM   #8
Rob in VA
Rob in VA's Avatar
I have the two-piece PF rotors on my 996 along with PFC pads (97s/01s and soon to be 06s) and couldn't be happier than my GT3 cup steels and my PCCBs.
Rennlist Member #: 080718-9078
2004 911 GT3 Seal Grey (sold)
Rob in VA is offline   Reply With Quote
Old 04-16-2009, 11:52 AM   #9
TripleM
User
TripleM's Avatar
Try Ferodo DS2500.....u will love it.
Old 04-16-2009, 01:07 PM   #10
Craig - RennStore.com
Basic Sponsor
Craig - RennStore.com's Avatar
Lightbulb Girodisc information
Pagid Oranges are not made for the rear of a 997 GT3 and indeed would be a bit of a waste if they were. Yellows are where it's at as noted above -
The OEM discs are rather soft, and in my opinion it is a mistake for Porsche to continue offering holed rotors.
Virtually NO race teams uses holed rotors, as they simply crack and groove like crazy – indeed they 'crack out' and 'groove out' FAR before they wear out.
The Girodiscs are approx $300 for each replacement disc, so this setup simply makes even more sense.
And when the COMPLETE COST is LESS than $600 per corner.......'value city' on a great product.
*These discs are on their 3rd season of Grand Am competition so they are a proven commodity on the race track as well and is the ideal blend of decent price and top performance*
PORSCHE 997 GT3 ROTOR PACKAGES:
SIZE:
Front: Factory 350 mm/GiroDisc 350 mm
Rear: Factory 350 mm/GiroDisc 350 mm
WEIGHT:
Front: Factory 25.6 lbs./GiroDisc 22.4 lbs. slotted
Rear: Factory 22.1 lbs./GiroDisc 18.2 lbs. slotted
Shoot me a note for some special pricing on these setups - approx $1000 LESS than the PFC.
rennstore@comcast.net
-Craig
425-765-1090, www.Rennstore.com -- assistance for selections welcomed
PAGID brake pads - Daytona winners & every podium position
GiroDisc F&R SLOTTED rotor upgrades (e-mail me) / Pad spreaders AVAIL. - e-mail
7+ yrs of business
<<My 930 12 yrs DE events, 514HP 930 track car
E-mail for any questions: Rennstore@Comcast.net
Craig - RennStore.com is offline   Reply With Quote
Old 04-17-2009, 02:02 PM   #11
porsche52
porsche52's Avatar
Thanks Craig for correcting me on the Pagid 4-4 rear brake pad issue! My parts guy Mike just talked to you on the phone this morning. I plan on going with the Pagid RS 29's now. Hope to do some buisness with you in the future. Just waiting on the rotors to show up!! Customer wants car done by Monday 4-20-09, going to Miller the following weekend, not looking to good though.
Old 04-17-2009, 02:15 PM   #12
Basic Sponsor
Right on, glad to help. Mike is a SHARP guy, congratulations!
Have him give me a ring about those 997 GT3 pads when they are needed -
-Craig
7+ yrs of business
Old 04-17-2009, 04:04 PM   #13
NoSubEDU
NoSubEDU's Avatar
Send a message via AIM to NoSubEDU
Craig, you sell OEM street pads for PCCB or just the MS pads?
'68 911S | '97 C2S | '97 993TT | '07 GT3
NoSubEDU is offline   Reply With Quote
Old 04-17-2009, 04:31 PM   #14
Basic Sponsor
Just the Porsche Motorsports pads from PMNA - the dealer price can't be beat for OEM -
Go to Suncoast - #1 for service, geat guys.
-Craig
7+ yrs of business
Old 04-17-2009, 06:17 PM   #15
sharkster
sharkster's Avatar
Send a message via AIM to sharkster
Been using these on the PDK car for a while and it's great that they're also lighter too. A lot of the TT guys have been upgrading to these as well. For the price etc.. they're a great option:
http://www.sharkwerks.com/products.php?pid=194
Alex "Sharky" Ross
www.sharkwerks.com
The Porsche Performance Center for EVOMS, TechArt, HRE, Tubi
Phone: 510-651-0300
Email: sharky@sharkwerks.com
2010 997 GT3 SharkWerks Project
2009 997S Sharkwerks ZTADPOL
2007 997GT3 RS SharkWerks ZKERMIT
2006 Cayman S SharkWerks RS350
sharkster is offline   Reply With Quote
Tags
964, 968, 997, boxster, disc, disk, floating, friction, giro, gt3, gyro, pccb, performance, porsche, rotor, rotors
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
