Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 997 GT2/GT3 Forum
Old 06-23-2009, 10:30 PM   #46
TeamDrugMoney
TeamDrugMoney's Avatar
So here is a question from what we have been told earlier today.......
"* The 997.2 GT3 rear wing is mounted on a 997.1 GT3RS base - only the top wing differs."
What is the difference in downforce from the 997.1 GT3 RS rear wing and the 997.2 GT3 rear wing? Would there be much of a reason, if any, to upgrade the rear wing on a 997.2 GT3?
1989 Carrera
2002 Boxster S - Sold!
2010 GT3 - Picked up in Stuttgart
TeamDrugMoney is offline   Reply With Quote
Old 06-23-2009, 11:09 PM   #47
Nizer
Nizer's Avatar
What is the "brown plug"?
Curve Addict
10 GT3 RS on order
08 BMW 535i
08 BMW X5
99 Chevy cargo van - tow vehicle
Nizer is offline   Reply With Quote
Old 06-23-2009, 11:12 PM   #48
Blaine S
Blaine S's Avatar
Send a message via AIM to Blaine S
Quote:
Originally Posted by black lamb View Post
The active engine mounts can be retro-fitted but only on the Gen2 - needs wiring etc. Andreas P told me it should be c. 1hr labour at the dealer so no need to wait for a factory build on this.
Excellent - thank you!
1997 Arctic Silver C2 Coupe - "Brunhilde" the visigothic princess
2010 Guards Red GT3 - "Loge" the prankster
Blaine S is offline   Reply With Quote
Old 06-23-2009, 11:18 PM   #49
buttons123
User
buttons123's Avatar
Quote:
Is it the plug in the engine bay that you can pull out to increase exhaust sound but really increases the resonance to an almost unbearable level??
buttons123 is offline   Reply With Quote
Old 06-23-2009, 11:37 PM   #50
911rox
User
911rox's Avatar
Excellent suggestion for a question! Buttons123 if you get the opportunity, this is a worthwhile one....
911rox is online now   Reply With Quote
Old 06-24-2009, 12:14 AM   #51
TeamDrugMoney
Quote:
Originally Posted by MJones View Post
Thank you to all!
This is what makes Rennlist a great place
Agreed 100%
1989 Carrera
Old 06-24-2009, 07:29 AM   #52
Adam2S
User
Very interesting and not a question that I thought to ask at the time, but on hindsight it does make sense. All I would say is he was at pains to show that the aerodynamics of the mk2 car were significantly better and had been balanced to give a near perfect 60:40 front:rear split in downforce. An RS rear wing might upset this balance? Do you mean you would want to do it for cosmentic reasons?
Adam2S is offline   Reply With Quote
Old 06-24-2009, 07:30 AM   #53
Adam2S
User
Oh and I forgot to say my driving instructor for the track sessions was former British Formula 1 driver Richard Attwood. What a lovely chap he is - was very polite about my driving!
Old 06-24-2009, 07:53 AM   #54
kryten
User
Not much more I can add.
You get a nut for the centre locks but no torque multiplier. There's a method of getting them on and only torquing to 100Nm - you then twist the centre 50 degrees that then lets you get to someone with a multiplier.
Dashboard comes with 'black leatherette' and NOT the full leather the display car had (it wasn't listed as an option the car had fitted but it definitely isn't standard)
Active mounts are 'best of both' - normal mounts for GT3 allow 17mm movement - active can restrict this to 2mm in their hardest setting.
Ride height of front lip is about 10cm and the one on the car they had looked very second hand!
Active mounts/Lift system available from September production (means the first 5 UK cars won't have it but they can be retro-fitted at dealer).
kryten is offline   Reply With Quote
Old 06-24-2009, 09:32 AM   #55
TeamDrugMoney
Quote:
I am not necessarily considering changing my rear wing at this point on my 997.2 GT3 when I get it. I only have about 60 track days under my belt and have much to learn myself before modifications make a difference in my lap times. That being said since the switch to an 997.1 RS rear wing is basically bolt on, it would be good to know what gains could be made.
I could see 2 gains, one is looks depending upon the personal preference and the other gain is function. No need for an open discussion on looks as this is an individual choice. The function is more the issue to me. It sounds like there may be no need to change the rear wing as the 997.2 GT3 has made drastic gains over 997.1 GT3. That being said I bet the 997.2 GT3 RS does not have the same rear wing as the 997.2 GT3. So then the question becomes, "do you really need more rear downforce?"
1989 Carrera
Old 06-24-2009, 04:06 PM   #56
Adam2S
User
ok here are a couple of my shots of the static display car...
ok guys what have you got to report from today's sessions?
Old 06-24-2009, 05:12 PM   #57
997gt3north
User
997gt3north's Avatar
Send a message via AIM to 997gt3north
- when you look at that new wing and compare it in shape / curvature to the mk1.RS wing it looks identical
- it isn't as wide but very nearly so
- it has a slight convexity to it (some modern race wings have the wing section in the center slightly higher and less curvature as the air is coming down over the car and hitting the wing at a steeper angle so this also makes sense)
- my guess is the new gt3.mk2 wing produces 90%+ of the downforce of the mk1 RS wing now having seen it better in pictures
- if it attaches to the base with the exact same hardware / brackets (this would be logical) the the wing can be further increased in attack angle by approx 16 degrees (thus being able to produce more than enough downforce before drag becomes a factor - a pure race wing (larger / better shape) could produce more downforce with less drag) but then even more front aero would be needed
- what i want to know is can that front lip spoiler fit on the mk1 gt3 / rs as its aero profile is clearly better but it still looks streetable versus a cup lip which isn't (yes they are easily changed)
997gt3north is offline   Reply With Quote
Old 06-24-2009, 07:24 PM   #58
kryten
User
Quote:
Someone in our group asked Andreas exactly that and the answer is no because the rest of the front is a different shape (aero) so the lip spoiler won't fit the Gen 1 997 GT3s.
Old 06-24-2009, 07:33 PM   #59
buttons123
User
buttons123's Avatar
No it won't fit, I asked today. The car is very similar in a lot of ways but he (Andreas) said most is new! Got a cup lip on mine and it catches now and then but it's not too bad, a lot softer and more durable than the original IMHO
Old 06-24-2009, 08:22 PM   #60
buttons123
User
buttons123's Avatar
Quote:
Originally Posted by cello View Post
Yes;
Will PDK be offered in the next generation; should we buy PCCBs or Steel, is the RMS fixed, will the RS be 4.0L & how much will it weigh, how much aftermarket can we use before voiding warranty, etc., etc., ......
I envy you! Please report back whatever you learn and your impressions!
OK Cello I know you being subtly humorous in this post but here's a mini report, will have to post rest over the next day or so, does anyone here know how to post/attach video clips on here, if so could you post the link to explain how, thanks. Back to the car.
The car was a nice looker in the "flesh" and grew on one as the day went on, what was more impressive was that they took the feedback very seriously from their in-depth survey and have been trying to satisfy the majority.
PDK was asked for in the survey by roughly 25% and whilst they think the manual box is the way to go now, they are NOT totally dismissing it at the moment. It's in their thought process for maybe the long term future as an option but not just yet. Where it loses out big time is the weight comparison- 30 kilos I think was mentioned, just too big a difference.
Interestingly Andreas said his favorite options would be:
PCCB - light and very efficient
Standard carbon fibre buckets seats - only 10 kilo per seat (15 kg new folding ones and 22 kg normal comfort seats)
PADM and after hearing just exactly what they can do for the driving experience I've changed my mind- they are a must have (and relatively cheap)
No roll cage
The pretty bits he didn't really seem interested in, although he liked the front lift option as this opens up the car to a good few more customers who had clearance issues, car parks, speeds humps etc etc.
Lots more to follow, pics, vid's and other stuff but the others lads have really done the job very effectively. Got to sleep
Tags
2010, 911, 997, andreas, event, fastener, gt3, mk2, morning, porsche, preuninger, preview, rms, session, silverstone, wheel
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
