Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 997 GT2/GT3 Forum
Old 08-12-2009, 12:05 AM   #1
sharkster
sharkster's Avatar
Send a message via AIM to sharkster
Question Different Rear Sway Bar on 997.2 GT3
Hey fellas a few of you were asking about the sway bar... It's actually thicker than the 997.1 version and a different part number.... Here you go:
And the clean engine, no cosmo:P
Alex "Sharky" Ross
www.sharkwerks.com
The Porsche Performance Center for EVOMS, TechArt, HRE, Tubi
Phone: 510-651-0300
Email: sharky@sharkwerks.com
2010 997 GT3 SharkWerks Project
2009 997S Sharkwerks ZTADPOL
2007 997GT3 RS SharkWerks ZKERMIT
2006 Cayman S SharkWerks RS350
sharkster is offline   Reply With Quote
Old 08-12-2009, 12:12 AM   #2
mooty
mooty's Avatar
to cure understeer?
PCA National Certified Instructor
HWFMR Team Director of "Unsanctioned" Track Events
Rennlist Member #021125-3378
mooty is offline   Reply With Quote
Old 08-12-2009, 12:54 AM   #3
GrantG
GrantG's Avatar
Engine looks great without cosmoline. What did you use to remove it and how long did that take? Is the front swaybar thicker too?
-Grant
73 Carrera RS 2.7 Carbon Fiber replica (240hp & 1,890 lbs)
Former:
73 911S Aubergine/Blk
89 944 Turbo S Blk/Blk
02 996 C2 Artic Silver/Met Blue
88 944 Turbo S Silver Rose/Burgundy plaid
96 993 C2 Coupe Polar Silver/Flamenco Red
98 Ferrari 550 Maranello Rossa Barchetta & Saddle
GrantG is offline   Reply With Quote
Old 08-12-2009, 01:03 AM   #4
lawjdc
lawjdc's Avatar
I would think that you would want to switch to the 997.2 GT3 springs and front bar also, if you were inclined to change the rear bar. Are there any other major suspension components that are different on the latest GT3?
2007 GT3
Past Porsches:
1973 911T/S, 1984 Carrera Targa, 1987 Carrera Cabrio, 2005 Carrera S
lawjdc is offline   Reply With Quote
Old 08-12-2009, 01:14 AM   #5
MJones
MJones's Avatar
Question??
Can you check if the pre-wiring is present for the dynamic motor mounts???
(connectors in the engine bay by the current mounts tied to the harness)
'10
MJones is offline   Reply With Quote
Old 08-12-2009, 01:23 AM   #6
MJones
MJones's Avatar
Quote:
New for MY10
• New wheel carriers on the front axle (like the 911 GT2) to reduce the tendency to understeer and improve driving stability at high speeds
• New spring, damper and anti-roll bar tuning with reduced-weight springs on the rear axle.
'10
Old 08-12-2009, 05:33 AM   #7
sharkster
sharkster's Avatar
This is what I posted on the first night... in the rear you can see the different style "springs". Using a larger diameter coil with less windings that's capable of supporting the same load (rate) reduces unsprung mass. In other words the spring is lighter but does the same job as before on the Mk1:P:
Just driving it the car is what you'd call more compliant on bumpy roads and less 'twitchy'.
Alex "Sharky" Ross
www.sharkwerks.com
Phone: 510-651-0300
Old 08-12-2009, 05:34 AM   #8
sharkster
sharkster's Avatar
Quote:
Originally Posted by MJones View Post
Question??
I'll be in Monterey all week for the show stuff so I'll have to do it this weekend;( I meant to look...
Alex "Sharky" Ross
www.sharkwerks.com
Phone: 510-651-0300
Old 08-12-2009, 05:35 AM   #9
sharkster
sharkster's Avatar
Also as you can tel the RMS isn't leaking:P
Alex "Sharky" Ross
www.sharkwerks.com
Phone: 510-651-0300
Old 08-12-2009, 08:42 AM   #10
997gt3north
User
997gt3north's Avatar
Send a message via AIM to 997gt3north
I thought in the initial press release they said they would be using less sway bar because they upped the spring rate?
Can anyone check if this is the same rear bar as the gt2?
I'm now running gt2 rear bar on softest of the 3 holes - what hole does this bar come on?
997gt3north is online now   Reply With Quote
Old 08-12-2009, 10:19 AM   #11
911dev
User
Quote:
I believe this is the way the engine's are coming on the .2 gt3's, or least so far.
911dev is offline   Reply With Quote
Old 08-12-2009, 12:55 PM   #12
sharkster
sharkster's Avatar
hey paul, I remember reading that too but if they're "upped" the spring rate I can tell you I can't "feel" that. If anything the whole ride etc... does "feel" softer. I don't have PET in front of me but I seem to remember the GT2 bar being different. Comes on tight....
Alex "Sharky" Ross
www.sharkwerks.com
Phone: 510-651-0300
Old 08-12-2009, 03:35 PM   #13
Larry Cable
Larry Cable's Avatar
Send a message via Yahoo to Larry Cable
Quote:
GT2 p/n is 997.333.781.94
'07 997 GT3 - apexing @ brunnchen
past cars:
'04 996 GT3
'99 996 GT3 ClubSport
'91 RS America
'96 993S (with RS upgrades)
'95 E36 M3
Larry Cable is offline   Reply With Quote
Old 08-12-2009, 03:36 PM   #14
Larry Cable
wonder if the shock rates are also different too (paired with the new springs)?
pretty major undertaking ...
past cars:
'04 996 GT3
'91 RS America
'95 E36 M3
Old 08-12-2009, 06:04 PM   #15
10 GT3
10 GT3's Avatar
The only thing that is not bigger/stiffer on the MKII is the front sway bar, which is thinner. Since the springs and shocks got stiffer, they probably went to the smaller front bar to get more turn-in. Since understeer wasn't really a problem on the MKI, the bigger rear bar is probably for more fun.
10 GT3 is offline   Reply With Quote
Tags
2007, 997, 9972, bar, diameter, gt2, gt3, hole, porsche, rate, rear, rms, spring, stiffen, sway, swaybar
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
