classifieds |
membership |
rennlist |
photo album     sponsors | upload photo | chat | marketplace     |
| Register | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Dealer Listings | My Recent Topics | Vendor Directory |
Thread Tools |
#31 |
User
im on a diet too! lol...but i don't think i can shave 15 pounds LOL
#32 |
Rennlist Member Join Date: Jun 2002
It think one could be a little creative in this space. LiPo technology is heavily used in other industries and applications. For the 14lb weight class, fairly heavy duty batteries are available which could be used in the application. The 100A maximum current draw capacity, with a 40A capacity.
http://www.batteryspace.com/lifepo4p...00arate-1.aspx Higher capacity than the Deka/Braille batteries, with LiPo technology. Makes you think at $356
Vaino '86 944 Turbo, Concours, 23.5K original miles and counting '87 924S - 60K, Autocross Only http://www.944T.com |
#33 | |
User
Quote:
The battery GT was talking about, the 14lbs with 100 min of reserve is model# VPR-S40P and is $2,999 Click here to view it . The lighter, cheaper ones you are referring have a much lower power reserve, i.e., 28min & 44min which puts them in same category as the light versions of the Deka/Braille. |
#34 |
Rennlist Member Join Date: Jan 2005
So many people pay the same, or more, for purely cosmetic items: $1365 for illuminated carbon door guards, $1625 for carbon rear console, $2225 for painted PCM panel, $2570 for leather speaker covers, etc., etc. It's a little steep but I have a lot less heartburn over $1700 for the lightweight battery than any of those cosmetic options... Yes, there are less expensive batteries but I like the fact that this is a factory original solution.
#35 |
Administrator
Still plays with cars. Lifetime Rennlist Member Join Date: Jul 2001
I wonder if the L-Ion battery requires a different charging system,i.e., changes to the alternator and or voltage regulator?
..Bob Frozen North Rep & ceramic rotor roaster Hey, wait for me! racing. |
#36 | |
User
Quote:
#37 | |
Rennlist Member Join Date: May 2001
Quote:
So you are not just paying for the battery but the charge system as well... pity, as I would love to retrofit it to my 997.1RS....
Cheers, Harold 2007 997 GT3 RS, euro spec, factory installed one piece racing seats/roll cage/plastic rear window. Black with orange. (Singapore) 1996 993 C4S, aventurine green with green interior- oh yeah!!!! (Perth Australia) Gone!!!! 2000 996 Turbo Protomotive PE700 1995 993 C2 1990 964 C4 1984 911 3.2 |
#38 | |
User
Tony from Voltphreaks here, just want to add, the 14 pound Voltphreaks VPR-S40P model isn't what is recommended for Porsche's. The model we recommend is the VPH750. It can still start the car in cold weather, and you don't need to leave it on a trickle charger (if you drive the car at least every 2 weeks or so), even though it has only 14Ah. The VPH750 is cheaper than the Porsche OEM option, though still much more expensive than a lead-acid battery. The VPH750 is comparable to 20 to 30 pound lead-acid batteries.
Based on your observations below for your situation, the VPH750 should last about 5 days, or so, but most applications with the VPH750 results in the battery lasting 2 to 3 weeks. In any case, you don't need jumper cables with any of the Voltphreaks batteries because they will shut off before the battery is completely drained, leaving enough power to still start the car by pushing a button to turn the battery back on. Though you can still carry jumper cables to give other cars a jump. The VPR-S40P is mainly for applications where you need the battery to run the car a long time when the alternator fails (ALMS, Rally, etc), though of course it would work fine in a Porsche. Risi Competizione ran a single VPR-S40P in their 430GT to win the 24 Hours of Le Mans in France this year! - Tony (voltphreaks.com) Quote:
#39 |
User
okay..... so i asked my dealer about this... and they told me it's NOT AVAILABLE as of yet...
???????? anyone have the same problem?????????? |
#40 |
Rennlist Member Join Date: Mar 2007
Correct - tried ordering on my car, won't allow it "yet"...
'05 Cayenne Turbo '08 R32 '08 Superleggera '08 ///M3 |
#41 | |
Rennlist Member Join Date: Nov 2008
Quote:
2010 GT3RS Blue/Gold, PCCB, Front axle lift, LiON Battery, NAV, AUX, XM. Feb 8th Build. 2009 C4S Meteor Grey/Carrera Red, PCCB, AMT Tech1-109's (Matte Black), FVD Brombacher Full Exhaust, PDK, Sport Chr Pkg Plus, Sport PASM, etc 2009 Cayenne GTS Meteor Grey/Sand, Porsche Dynamic Chassis Control, 18" Nitto Terra Grapplers/Victor Zehn (Matte Black) |
#42 |
User
#43 |
Well, the battery isn't supposed to be available until early next year and some of the carbon stuff won't be released until March production. Hope that helps.
#44 |
Rennlist Member Join Date: Apr 2002
From the order guide:
191 Lightweight Lithium-Ion Battery Available beginning approximately 01/2010 EZC Carbon package $790 Gear lever[partially, 4.1a] and upper section of handbrake finisher[4.3b] in Carbon finish. Alcantara finish on gear lever[4.1a] including decorative trim on shift pattern[4.1e] in Volcano Grey with shift pattern in White, and handbrake lever[ 4.3a] including inlay in Volcano Grey with GT3 logo in White. Note: available from approximately 03/2010. EZD Extended carbon package $1,760 Side air vents[2.5a] and central air vent[2.6a] in Carbon finish. Side air vent slats[2.5b] and central air vent slats including switch trim[2.6b] in smooth leather finish in interior color. Note: available from approximately 03/2010.
'07 GT3 |
#45 | |
User
Quote:
| Tags |
| 2010, 997, add, batteries, battery, braille, car, gt3, ion, lion, lithium, porsche, replacement, rs, voltphreaks |
| Thread Tools | |
