997 GT2/GT3 Forum 2005-2012
Why not keep the exhaust valve open
Old 01-31-2010, 06:28 AM
fun2k
fun2k's Avatar
Originally Posted by brim
guys, what is "unplugging" mean? I am guessing like other cars, there is a valve in the exhaust system that opens at a certain RPM? Is it different than just always having the sport button on? Is this a simple operation?
In sport mode the valve opens after 3000rpm,without sport mode they open at 4000.you can hear the sound change in sport mode when the car is at standstill but once you start driving the valves stay closed below 3k and 4k.
i dont know what unplugging is technically but what it does is let the vavles stay open all the time especially below 3000rpm where the car sounds like poo with the vavles closed.
Old 01-31-2010, 07:43 AM
ttdan
ttdan's Avatar
unplug the electrical connector, not the vacuum hose!
Old 01-31-2010, 11:19 PM
Born2Run
Born2Run's Avatar
Just unplugged mine today and damn it sounds great. Never going back!!
Old 02-01-2010, 12:12 PM
mikegee
mikegee's Avatar
can anyone post the pics of where this connector (s) is/are. Is there more than one to disconnect?
mike
Old 02-01-2010, 01:09 PM
bob_dallas
bob_dallas's Avatar
I've searched around on this one but haven't seen a definitive answer. Is there no performance hit for leaving it unplugged all the time? I'm trying to figure out if there's a need for the valves to close for backpressure or otherwise in the lower RPMs. Has anybody dyno'd after unplugging to compare?
Old 02-01-2010, 01:51 PM
bob_dallas
bob_dallas's Avatar
mike
https://rennlist.com/forums/997-gt2-...e-cheap-3.html
Old 02-01-2010, 02:31 PM
Born2Run
Born2Run's Avatar
mike
The connector is on the passenger side of the engine compartment. There is only one connector to unplug. Squeeze the small metal spring loaded bar and pull down. Easy as that. Hope the pictures help.
Old 02-01-2010, 03:00 PM
mikegee
mikegee's Avatar
thanks!!!!
Old 02-01-2010, 03:30 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,597 Likes on 739 Posts
I've ran it unplugged for 12K miles, no issue.
It is the same as runninng it with the sport button on over 4000RPM or so, no problem.
Old 02-01-2010, 03:48 PM
ttdan
ttdan's Avatar
you may want to put some electrical tape over the exposed plug & socket, keep the crud out.
Old 02-01-2010, 07:01 PM
fun2k
fun2k's Avatar
Just ran it with the stock exhaust unplugged,and boy the droning is bad. With the windows up it will probably make you deaf and with the windows down i felt sorry for the other drivers. The sound below 3000rpm unplugged is way different than what you hear above it,it sound like a supra exhaust times 10 + drone.
Old 02-01-2010, 07:19 PM
sharkster
sharkster's Avatar
For those that need to keep things "quiet" Mikymu has a nice write up on how/what
http://sharkwerks.com/porsche/techni...ification.html
Old 02-01-2010, 07:24 PM
Izzone
Izzone's Avatar
The drone is bad with a stock rear exhaust......but once you install a Sharkwerks exhaust there is no drone with it unplugged
Old 02-01-2010, 07:52 PM
On Pole
On Pole's Avatar
Default Flaps
http://www.youtube.com/watch?v=J0Q5Szx021s
Old 02-01-2010, 07:59 PM
Born2Run
Born2Run's Avatar
There is no droning with the SharkWerks bypass and the connector unplugged. If you can't live with the OEM exhaust and the drone, go with SharkWerks...you won't be disappointed!!
Quick Reply: Why not keep the exhaust valve open
