997 GT3 Ceramic Rotor replacement
Has anyone seen this. I saw it in Total 911 mag.
Finally some light at the end of the tunnel.
Wonder how they will perform
http://www.design911.com/Porsche/997...-cmo117-ct344/
That's a huge discount from OEM - hope they're just as good (or better).
How does the weight of 8.9kg compare with OEM front donuts (without bell)?
Those are conventional cast iron rotors rims to reuse the PCCB hats, nothing new. Also they don't fit the 997TT or Carrera.
Brembo GTR or StopTech STR weigh about the same as Porsche stock PCCB, and they are both race proven.
Optionally, both Brembo GTR and StopTech STR can be ordered with CCB rotors, and save close to 30 lbs over the stock PCCB, or 70/80 lbs over a 997.1/997.2 GT3/GT3RS with standard brakes.
Odd - it says they are ceramic and from the description they don't sound just like conventional cast iron rotors. Maybe it's some sort of hybrid with ceramic over cast iron? I'd still go with the StopTech or Brembos though either way.
Steel is heavier than carbon is a pretty broad statement. I don't have the details but Rad has proven to be extremely precise with things like this so I would tend to believe his claim. I'm not sure he has a reason to stretch the truth here either.
Hi Rad,
Whats the price of the Brembo GTR with CCB rotors for the 997?
Do you have the exact weight of the OEM PCCB:s and the Brembo CCB:s?
Also the weight of the OEM PCCB calipers versus the Brembo ones?
Rgds Lars
Rgds Lars
Received 1,720 Likes
Believe I'm happy to be proven wrong on this, especially since I swapped from PCCB to steel on my RS order. However to date, nobody has been able to produce real numbers to back up the claim.
I don't think Rad ever said the STR rotors are lighter than PCCB. I believe he said that the overall setup is lighter because the calipers are lighter, which offset the weight of the iron rotors.
