997 GT2/GT3 Forum 2005-2012
Voltphreaks 5.5 lbs lithium-ion nano battery
Old 02-26-2010, 06:16 PM
mikymu
mikymu's Avatar
Smile Voltphreaks 5.5 lbs lithium-ion nano battery
Battery, we need them to turn our engine over and power electronics devices in our modern vehicle. They are as heavy as they come, 40, 50 and some times 60+ lbs for conventional lead acid battery. We have one of those lead anchor in our Porsche and sits right on top of the fuel tank and front axle. I want the dead weight off and replace with a smart and efficient lithium battery. My criteria are as follow:
Weight: Less than 10 lbs is a must. Our OEM battery is over 40 lbs. I want this weight off as much as possible
Brain: Yes, you read that right. I want a battery with brain where it can shut off itself when power is low so I don't have to jump start my car or hot wire from the fuse box just to pop the front hood
Protection: Prevent overcharge or discharge related damage
Remote control: A remote push button to turn the battery back on if it shut itself off due to low voltage
There are several options on the market including the new Porsche Li-ion battery. But the problem with these battery is that they weight more than 10 lbs (13 lbs for Porsche brand), has no brain or remote control and cost some pretty pennies.
After much research, I decide to get a Voltphreaks 5.5 lbs VPH 750 battery. It has everything I was looking for and weight merely 5.5 lbs and cost less than the Porsche battery. Here is their website with some technical description: Voltphreaks 5.5 lbs VHP 750 lithium-ion nano battery
Here is a look of the battery switch process and comparison
Voltphreaks fresh out of the box
Let's remove the heavy OEM battery by first removing the plastic cover then loosen the right base anchor bolt
Remove the 3 lbs OEM battery base
Battery remote control wire can gain driver compartment access through a left side black plastic cover (this opening is used for interior air filter if you have a right sided driving vehicle)
Remove the two Philip's screws and gently pull the cover back to revel interior access
Drop the remote control wire through the opening. I wrap some electrical tape on the wire section that makes contact with the body of the car to prevent tearing the wire cover
Remote switch at the driver side compartment next to the foot pedals. I zip tie the switch next to the black plastic bracket. The top of your foot will kick the plastic bracket and will not touch the switch
OEM vs Voltphreaks battery
41 vs 5 lbs lol
OEM battery plus battery base come up to 44 lbs - that's about an extra 7 gallon of fuel you carry around every day
Old 02-26-2010, 06:17 PM
mikymu
mikymu's Avatar
The hardest part of the whole switch is making the battery bracket. You don't need to make something fancy like what I did but this give you a general idea on how to secure the smaller Li-ion battery.
I got an aluminum sheet from ACE hardware for the bracket since they are light and easy to work with.
I measure out the length and width of the battery and the distance between two bolts on the body panel (this is where you secure the battery) facing the battery compartment and bend the sheet with the help of a vice. Wood block was used to sharpen the bend (beat the crap out of metal sheet lol)
Test fit looks pretty good
I also made a center brace to prevent the battery from moving up and down. I drilled 4 holes on the center brace then secure it with aluminum rivets. Ignore the extra holes ... they are for cooling lol.
Flat side of the rivet facing the battery. I used couple self adhesive plastic spacer on the center brace to help it fit perfectly
Here is a look of the finished brace
I cut out a none slip plastic mat from Lowe's for the bottom and back side of the battery for extra cushion
You will have to get two longer bolts (about the twice the length of the OEM bolts) from a hardware store to secure the bracket. You may also need to bend the aluminum bracket ever so slightly to make it fit right. Here is what is looks like once installed
Now you have lost 39 lbs total with this mod. This is about 6 to 7 gallon of fuel in weight so the front of the car will be slightly higher. I measured about 1/4" or 6 mm higher each corner on my car. To compensate for this change, I lower each side of the car by turning the suspension height adjustment by two 360 degree turns.
Finish product with everything installed. Connect the remote control wire and push the little button next the the red positive terminal and you are in business!
The car felt great yesterday at Laguna Seca with 39 lbs lighter in the front. The car tun in better. Battery works fantastic too! I intentionally left the interior lights on with both doors open and front hood and rear engine lid up to see how long it take to drain the battery. It took more than 4 hours for the battery to trigger the low voltage shut off. All I had to do is push the remote bottom and we got juice again. Start the engine and the battery was quickly charges. I had no problem at Laguna Seca yesterday and the battery work great with all the electronics without triggering the low voltage shut off. I will give more feedback in 3, 6 and 12 months for long term follow up.
Addendum:
Rad aka NJ-GT gave me a good suggestion that I should put some form of cover between the Li-ion battery and the fuel tank below just in case something happen to the battery that it won't damage the fuel tank case as shown below.
It's a pretty easy mod. You can get a thin aluminum sheet form your local hardware store. Trace out the shape of the heavy OEM battery tray and cut it with a metal sheet cutter.
Test fit the aluminum sheet and I wrap the sharp edge with door edge molding
Finally I cut out a none slip plastic mat from Lowe's for the aluminum sheet and the cover between the Li-ion battery and the fuel tank case is done
Dervish (08-03-2020)
Old 02-26-2010, 06:25 PM
cfjan
cfjan's Avatar
Very nice!! Nice job on the bracket too!
Old 02-26-2010, 07:04 PM
mikymu
mikymu's Avatar
It was worth the trouble
Old 02-26-2010, 07:10 PM
tshih
tshih's Avatar
Great job as usual posting interesting mods.
However, the costs of the VPH750 is $1300 which is still quite pricey compared to say an Odyssey 680? alternative. I know the Odyssey weighs over 10lbs (I think around 18lbs) and doesn't have the undercharge protection. I'm sure one can get (or make) an add-on switch which monitors the discharge to cut the flow of electricity from the positive terminal for the $1000 price difference.
Also how safe is the technology in this application? The alternator may be providing a lot of current during recharging. Are you concerned about possible battery fires etc. that Li-ion batteries are known for.
Still, best of luck with your pioneering applications of current technology.
Old 02-26-2010, 07:22 PM
mikymu
mikymu's Avatar
Yes it's not cheap but it is suppose to last 5- 10 year s and I would have gone through couple conventional light weight battery like the Odyssey not to mention having to jump start the car when it's dead - a no no for track. I think the price is well worth it considering the weight advantage and "brain" benefit. I am not knowledgeable enough to make a low voltage protection circuit board. As far as Li-ion battery and alternator load. Voltphreaks battery suppose to draw less current from the alternator as mentioned from their website:
Advantages:
1. Weight, much lighter than a comparable lead-acid battery.
2. Can be mounted in any orientation.
3. Can be "deep cycled", meaning discharged fully without damaging the battery.
4. Has a LVC (low voltage cutoff) that will prevent overdischarge. This cuts off the battery before it's fully discharged, which means never having to return a dead battery again (for example, by accidentally leaving something on).
5. Has a full fault protection circuitry to protect the battery, preventing damage to the battery from misuse and overcharge.
6. Maintains higher voltage and charges very efficiently, less load on the alternator and more efficienct than a lead-acid.
7. Can be deep cycled, and charged/discharged at high rates.
8. Remote pushbutton included, allowing battery to be turned on and off remotel
Will post long term feedback
Old 02-26-2010, 07:40 PM
Md11skipper
Md11skipper's Avatar
Mike, another exceptional post! Thank you.
Old 02-26-2010, 08:08 PM
Nizer
Nizer's Avatar
Received 1,735 Likes on 918 Posts
Great post. One question, are there any issues with having to reset radio, electronics, etc. when the battery shuts itself off to preserve charge?
Thanks.
Old 02-26-2010, 08:51 PM
P.J.S.
P.J.S.'s Avatar
subscribed
Old 02-26-2010, 08:55 PM
roberga
roberga's Avatar
PJ: where is she?
Old 02-26-2010, 08:56 PM
P.J.S.
P.J.S.'s Avatar
^ picked up today in Texas
Old 02-26-2010, 09:04 PM
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
mikymu,
I hope you don't mind but I have copied your posts to the DIY forum for the GT3. Congratulations!
Best,
Old 02-26-2010, 09:08 PM
GT3
GT3's Avatar
Originally Posted by mikymu
How much to make me one(battery bracket)?
Old 02-26-2010, 09:28 PM
mdrums
mdrums's Avatar
mikymu, wow another great post! I was all excited because I was looking into a Braile battery but then I saw the price of this battery.
My car is a weekend driver and some during the week and I track it 10-15 times a year. I am still unsure if these type of battery's are good for a regular almost dailey driven car like mine.
Old 02-26-2010, 10:22 PM
Basal Skull
Basal Skull's Avatar
I got an aluminum sheet from Ace hardware for the bracket since they are light and do not conduct electricity.
great write up, planning to do the same for my 993tt this summer. I'm sure it's probably a typo but aluminum does conduct electricity very well!
Quick Reply: Voltphreaks 5.5 lbs lithium-ion nano battery
