Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > 997 GT2/GT3 Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 05-13-2010, 01:49 PM   #1
Bob Rouleau
Administrator
Still plays with cars.
Bob Rouleau's Avatar
Default Hoosier R80 R100 on MK2 RS
My tire dealer has told me to use the Hoosier slicks on my '10 RS. Wheels are 18 inch dia. Apparently they are the spec tire for the Cup series.
Does anyone know what hot pressures I should shoot for? I've used the R6 but this will be a new experience.
Best,
To remove this ad, register today or login if you already are registered!
..Bob
CI Rennsport Region PCA
Bob Rouleau is offline   Reply With Quote
Old 05-13-2010, 02:28 PM   #2
Z06
User
Z06's Avatar
Bob, what spec series?
The Patron series uses Yokohama slicks...maybe consider them..they are an exact fit and they are that good!
But the other concern is the ABS causing the Ice Mode?!
Z06 is offline   Reply With Quote
Old 05-13-2010, 03:19 PM   #3
85Gold
85Gold's Avatar
Best,
Bob,
When we ran them on the 996GT2 R100's we shot for 30psi Hot. Jeff Spears @ Hoosier is the man for any questions.
Peter
aka The Farmer
"A society that will trade a little liberty for a little order will loose both, and deserve neither"
2004 GT3 With a few TSB's " The Fugly one"
2006 Civic Si #61x 8.5k rpm NASA TTD Got Rice
2014 WRX Hatch Dog Hauler
85Gold is offline   Reply With Quote
Old 07-18-2011, 09:10 PM   #4
Hoosier_Daddy
Hoosier_Daddy's Avatar
Any more on this?
I'm headed out to the Glen in a couple of weeks and will be using the R80 up front and R100 in rear. I've lots of experience with the Michelin and Yoko slicks, but this will be my first on the Hoosiers. Like to know the thinking on both cold and hot psi.
TIA
Past Flames:
2007 GT3 • 2001 911 Turbo
1991 964 • 1994 964 Cab
1995 993 • 1981 911 SC
1986 911 • 1986 944 Turbo
1999 996 • 1985 944
Hoosier_Daddy is offline   Reply With Quote
Old 07-18-2011, 09:23 PM   #5
mdrums
mdrums's Avatar
Location: Fairfield Inn, Courtyard, Springhill Suites, Marriott and Hilton hotels
https://www.facebook.com/profile.php?id=1148135094
I'm seeing more guys at the track in the race groups using Yoko slicks these days. Ask ViperBob on these forums about them he has 2 guys using them and they like them a lot better than the Hoosiers they use to use.
Mike
2012 Carrera GTS - The Official "Wanna Be Aero Beetle"
PCA National Instructor #200911210 Chin and PBOC Instructor
mdrums is offline   Reply With Quote
Old 07-18-2011, 09:38 PM   #6
24Chromium
24Chromium's Avatar
We've got folks out here using the Yokos as well. Saw some with red lettering on them. R6s are still the most popular on the GT cars.
997.1 GT3 Cup
2009 GMC 2500 HD Sierra
_still_ waiting:
991 GT3
fond memories:
997.2 GT3 RS
997.2 GT3
24Chromium is offline   Reply With Quote
Old 07-18-2011, 10:02 PM   #7
Hoosier_Daddy
Quote:
The Yoko slicks are more than the Hoosier slicks. I've run the Yoko slicks for many years... good tire but $500-600 (+/-) more than the Hoosier radial slick per set. I buy a few sets and I've saved the money for another set. (Plus I am running the 19 inch wheels.)
Please guys -- this is not a thread about what tires are better... I would like people with experience to share what they know on the Hoosier radial slick in the R80 or R100 compound.
Past Flames:
1999 996 • 1985 944
Old 07-18-2011, 11:02 PM   #8
mdrums
mdrums's Avatar
Ok I'll shut up.... ;-)
Mike
Old 07-19-2011, 12:03 AM   #9
jrgordonsenior
jrgordonsenior's Avatar
Too funny Mike.....
OK I've run the R80/R100 combination. I know that Hoosier tells everyone to run them at 30 hot and that seems to be a good place to start. I would go out dead cold at 24 front 23 rear and bleed them down to 29-30 after 5-6 laps. If you were going out cold for a race I would drop to 22/21....
I found them to be very slippery when cold so take it easy for a few laps before you push them. I got over 20 HC's on that set remarkably....
JR Gordon
99' 3.4/3.6 996
POC- GT3 Champion 2010, 2011
NASA- ST2 So Cal Champion 2010, 2011
Let's not talk about 2012.....
jrgordonsenior is offline   Reply With Quote
Old 07-19-2011, 10:06 AM   #10
Hoosier_Daddy
Quote:
Originally Posted by jrgordonsenior View Post
Too funny Mike.....
That's what I've heard; 30 hot is the target. I will speak with Hoosier prior to the weekend, but figured there be a couple of people who've run them on the forum -- thanks for the info.
20 HCs is remarkable and consistent to what we've been told with about the tires. Actually, seems to be about the same as R6s based on my previous experience. (20-24 heat cycles)
I usually see about a 10 psi rise for a 20 minute session; I'll look at that 20 to 21 psi range cold start. I have not been to the race track with my GT3 yet so it's both a new car and tire for me.
Should be fun.
Past Flames:
1999 996 • 1985 944
Old 07-19-2011, 10:43 AM   #11
amaist
User
amaist's Avatar
Quote:
I did that and ruined the fronts. The first few laps at such a low pressure ruin the sides of the tire. You need the center of the tire to hold it up.
Start at 24 and bleed them down as needed.
29 front 30 rear or something in that range as you get used to them and figure out what works for you.
Good tire. Went away for me when I corded it. Stayed together until then.
20 HC is about right.
amaist is offline   Reply With Quote
Old 07-19-2011, 11:52 AM   #12
Seth Thomas
30 hot is a good target and starting at 24 a good starting point. With 24 starting and bleeding down as needed the tire will have a little bit more support in it coming out of the pits. These tires don't like to be beat on right out of the pits with a low tire pressure in them. Give them a few easy laps to get some heat and pressure in them before really driving hard on them. This will help them to last longer and keep from cording.
Seth Thomas
Professional Driver and Coach
YouTube Channel
Keep up with my 2013 Season
BIMMERWORLD RACING
Seth Thomas is offline   Reply With Quote
Old 07-19-2011, 02:04 PM   #13
Hoosier_Daddy
Quote:
Outstanding -- Thanks Seth. (and amaist)
Past Flames:
1999 996 • 1985 944
Old 07-19-2011, 03:19 PM   #14
MSRPorsche
User
MSRPorsche's Avatar
I've run the R80 front and R100 rear combo' as well as R100s all around. We targeted 30psi hot at first but found an unusual wear pattern on the fronts. Increasing the hot target to 32psi worked better and resulted in more even wear across the surface of the tire. The heavier weight of the street GT3s over a Cup or race prep'd car called for the higher pressures. Alignment settings are also a factor. It seems we had the front camber at 3.25 degrees negative and rear was 2.25 negative as I recall. Tire widths were 250 front and 305 rear on a 2008 GT3.
MSRPorsche is offline   Reply With Quote
Old 07-19-2011, 04:05 PM   #15
Hoosier_Daddy
Quote:
I've been down that road before having run slicks on the heavy 996 Turbo. Seems most of the advice the manufacturer's would tend to give pointed toward "a little higher" pressure due to the weight of street cars. (32-34 range) I usually kept track of the tread temp with the pyrometer and don't recall ever going above 220 degrees with most common temps in the 200 degree range... so we never really worried about the psi too much. With that said, I seemed to have the most success with low-mid thirties psi with both Michelin and Yoko slicks... I would bleed down after the first session of the day from the high thirties. I am afraid of over heating the shoulders if the pressures are too low. I suspect the camber will be -2.5 front and -2 rear, but we have not aligned the car yet.
No matter what some my think -- I feel 3000 + pounds is pretty heavy.
Glad I posted to this thread... getting good feedback.
H_D
Past Flames:
1999 996 • 1985 944
Paid Advertisement
Tags
18, 964, bbs, compound, destroyed, hoosier, hoosiers, hot, motorsport, optimal, porsche, pressure, pressures, r100, r80, r80r100, sale, slick, slicks, tire, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Privacy Statement - Terms of Service - Jobs
Emails & Contact Details
