997 GT2/GT3 Forum 2005-2012
Catastrophic Coolant Hose Coupling Failure Registry
Old 09-21-2010, 08:38 PM
deputydog95
deputydog95's Avatar
Default Catastrophic Coolant Hose Coupling Failure Registry
I would like to limit this registry to strictly people who have had this problem. It would be great to see just how expansive this issue really is. This is a serious problem and could easily result in a fatality under the right circumstances. Please avoid discussing the problem and post questions etc elsewhere so that the thread does not get diluted.
The posts should read as follows:
Year:
Model:
Mileage:
Circumstances surrounding failure:
Specific Coupling:
Repair Solution:
Old 09-21-2010, 08:40 PM
deputydog95
GT3
8500ish
Turn 17 at Sebring Raceway
Top driver's side behind the alternator
Engine is currently out at dealer. It is my understanding that it will be warrantied. Will update post when repair has been completed.
The following 2 users liked this post by deputydog95:
cdixon (10-08-2021), dak996 (07-31-2019)
Old 09-22-2010, 12:13 AM
4porsh
4porsh's Avatar
Year: 2004
Model: 996 GT3
Mileage: 40k
Circumstances surrounding failure: Button Willow Raceway park
Specific Coupling: J-fitting right side top of motor
Repair Solution: Safety wired J-fitting to near by bar for tension. Repaired myself.
dak996 (07-31-2019)
Old 09-22-2010, 12:29 AM
Terry L
Terry L's Avatar
Year:2007
Model: 997 GT3
Mileage: around 29,000
Circumstances surrounding failure: Shenandoah Circuit (noticed coolant leak while in paddock)
Specific coupling: top left rear of motor
Repair: warranty replacement of manifold with leaking joint
Old 09-22-2010, 12:27 PM
datax
datax's Avatar
Few years old but add me to this registry. Hopefully, Porsche will see it. https://rennlist.com/forums/996-gt2-...ml#post4433237
Old 09-22-2010, 01:02 PM
Bob Rouleau
Still plays with cars.
Bob Rouleau's Avatar
996 GT3 2004 in 2006 blew the fitting out of the driver's side of the coolant pump on track at around 18,000 miles. Same car in 2008 blew the right side fitting out on track at around 24,000 miles.
Based on observations at my regions DEs it seems that all of the 2004 GT3's blow a coolant line sooner or later.
Old 09-22-2010, 01:18 PM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
2004 GT3
15000 miles
Laguna Seca T9
hose was in front of rear right tire.
Old 09-22-2010, 04:03 PM
911SLOW
Admin
911SLOW's Avatar
Row GT3 clubsport
40000klm
road
Old 09-22-2010, 07:03 PM
Larry Cable
Larry Cable's Avatar
Received 3,446 Likes on 2,252 Posts
Year:
Model:
Mileage:
Specific Coupling:
Repair Solution:
you posted to 996 GT3 an TT forums also?
Old 09-22-2010, 11:22 PM
blake
blake's Avatar
I had cited my personal experience on Datax' thread back in 2007...
Year: 2004
Model: 996 GT3
Mileage: 10k
Circumstances surrounding failure: Miller Motorsports Park - 100+ degree track day, and hose got brittle and slipped off connection
Specific Coupling: bypass hose on the right side of the enginer
Repair Solution: Use Red Line Water Wetter and replace all hoses and connections once per year (cheap insurance)
-B
Old 09-22-2010, 11:58 PM
roberga
roberga's Avatar
Originally Posted by mooty
2004 GT3
15000 miles
Laguna Seca T9
Where did you end up?
Old 09-23-2010, 12:31 AM
lawjdc
lawjdc's Avatar
GT3
6500 miles
Laguna Seca Turn 2 - 360 spin, kept it on track
coupling hose on back side of motor
repair solution - Matt at Sporthaus (now Reno Rennsport)
Old 09-23-2010, 12:36 AM
Backmarker
Backmarker's Avatar
Year: 2004 996GT3
Model: gt3
Mileage: about 20000
Circumstances surrounding failure: thunderhill dumped all coolant as I entered track at WOT, limped off track at back straight
Specific Coupling: coupling did not fail, hose split down the middle. hose directly off of water pump at right side of motor as viewed from rear of car
Repair Solution: new hose
Old 09-23-2010, 12:37 AM
johnr265
johnr265's Avatar
Year: 2004
Model: 996 GT3
Mileage: about 51k
Circumstances: Pocono along back straight
Coupling: Metal press fitting separated (? location)
Solution: Repaired with stock part
Old 09-23-2010, 12:47 AM
Wolk's Wagon
Wolk's Wagon's Avatar
996TT
35,000 miles
Texas World Speedway turn 3
Right side large J hose split down middle
Replace all coolant lines
Quick Reply: Catastrophic Coolant Hose Coupling Failure Registry
