Jackpoint Jackstands ???
Location: Trying to be the driver my car wants me to be
never used them but have seen the ads in grassroots Motorsports
I could not use them without driving my car on to some wood planks because I do not think the with the piece that goes on the jack that I would be able to get under my car
and I hate wood planks
just got an ac jack - bye bye wood planks hopefully
Hey TDM, I don't think u'd get it under your car...I have an AC jack too which sits about 85mm high at the end with the rubber top and it only just clears the car by a few mm's. Those plates alone look 50mm high without taking the jack into consideration which looks at least another 100mm ... good idea, wrong car i think... could b wrong
I just threw this thread up to troll and see who knows what about it and see if there are alternatives out there with a similar theory. I guess if you just had two jacks you could do the same, withouth the security of the jack stand.
You will still need wood for the rear of the car to put all four points on stands
GT3 player par excellence
when working at home, i like AC jackes, i have both the long and short one. even then i need to put rear tires on 2x6 for the long jack to reach it. the short jack... forget it.
for track, get a lwt thing, just drive car over 2x boards. AC jack is very heavy and of a shape hard to pick up. you will break your back.
Received 1,736 Likes
If you can't get the jack under your car (car too low) just cut some 2 X 10 18" long, cut a 45 or 30 degree angle on the one end and drive on them before you jack! Cheap and easy.
Bill
Bill
