997 GT2/GT3 Forum 2005-2012
New Air Box
Old 12-23-2010, 06:57 PM
mkozink
mkozink's Avatar
Another fantastic piece of design and fabrication from the inimitable Linton elves.
Old 12-23-2010, 08:39 PM
P.J.S.
P.J.S.'s Avatar
wow
Old 12-24-2010, 12:08 AM
Schmidts Cat
Schmidts Cat's Avatar
Originally Posted by Robert Linton
Nothing like this for Z8 - would not make much of a difference. For Porsche, however, 10 rear, high up pounds are significant.
Oh, but it does look so sweet! Nice work.
Old 12-24-2010, 02:10 AM
FFaust
FFaust's Avatar
Nice, and no claims of hp gains
Old 12-24-2010, 02:39 AM
NJ-GT
NJ-GT's Avatar
WOW!!!
Old 12-24-2010, 06:27 AM
nct510
nct510's Avatar
the only one to be made? seriously? -10 lbs and gorgeous.
Old 12-24-2010, 10:41 AM
Robert Linton
Robert Linton's Avatar
If, because the interior is smoother than the metal air box, there was any power gain, it would be so small as to be totally insignificant. On the other hand, the weight saving is possibly the largest single item achievable for this engine. Having said that, for quite large dollars, additional lbs could be removed from the engine on a bit by bit (static and rotating) basis, e.g., metal matrix composite components, titanium components, other carbon components, etc.
Old 12-24-2010, 01:55 PM
911SLOW
Admin
911SLOW's Avatar
Exactly Robert!
Besides it is not even sure that you would see a small gain.. maybe a small loss depending on the unique characteristics of the intake and shape of air flow path..
A small increase in the surface roughness for cylinders or sphere like objects may actually decrease the drag coefficient and alter turbulent flow.
The penalty of the increase in drag from a higher friction surface is much smaller than the gain from the pressure drag due to separation drop and hence increased velocity of air entering the cylinders in our case.
There are a lot of studies available using Reynolds number with valid results comparing drag coefficients for rough and smooth surfaces and their effects on turbulent flow.
Porsche has decided on newer cars that the plenums and intake remain a bit rough with lets say micro dimps. I don’t think they did that by accident.
In any case we are talking about very small ± hp differences. The real gain is the weight loss !
keep it coming and give us here an update on current weight. : )
Old 12-24-2010, 02:43 PM
FFaust
FFaust's Avatar
^ Golf ***** come to mind.
Old 12-24-2010, 04:25 PM
Robert Linton
And, indeed, and not accidentally, the inside of the carbon fiber air box is a bit rough but a bit smoother than the original (and, of course, it can be made more rough or more, even completely, smooth). In any event, it will be placed on a Porsche dyno and compared with the results from the metal air box.
As to weight, my old 964 has dropped below 2000 lbs.
Old 12-24-2010, 04:29 PM
P.J.S.
P.J.S.'s Avatar
Robert - if I search will I find pics of said featherweight 964?
Old 12-26-2010, 11:21 PM
luiscarlos
luiscarlos's Avatar
OEM RSR plenum is made of CF like this one
Old 12-27-2010, 06:25 AM
GuyR
GuyR's Avatar
Robert,
The airbox is as beautiful as your other pieces. Do you have an aim for a final target weight, or will you just keep going until you find no more parts to change?
Guy
Old 12-27-2010, 09:41 AM
Robert Linton
As you can see from the Cartridge label on the RSR Airbox pictured in an issue Race Engine Technology magazine, I am somewhat familiar with it.
Old 12-27-2010, 10:37 AM
silverboy
silverboy's Avatar
You da man!
Quick Reply: New Air Box
