997 GT2/GT3 Forum 2005-2012
Centerlocks - I'm out! ....Hello 5-lug conversion!
Old 08-19-2011, 11:08 PM
DJN
DJN's Avatar
Default Centerlocks - I'm out! ....Hello 5-lug conversion!
Hi All!
Lastest Update: See Article in Excellence (Feb 2012 issue) "Five Lugs or Bust" on sale Dec 27/11.
NEW: I just arranged a Rennlist Group Buy at SUNCOAST for anyone interested in doing the conversion, Call Ric Knab 877-923-1700.....see pricing on Post #91
NOTE FOR ALL:Conversion confirmed go to Post # 52 on page 4 ! ALSO NEW FINAL PHOTOS in Posts #62 and#63 on Page 5 - ENJOY!!!!
Additional Notes: Wheel and tire sizes, theoretical offsets for the CL to 5 lug conversion are precisely the same for 997.1 GT3/RS and 997.2 GT3/RS.
Note that the Gen 1 cars use a 5mm spacer in the rear, so the wheel offset on a narrow body for example, is actually 68mm, but stepped out to 63mm when combined with the spacer. If you are ordering new wheels just use the standard Gen2 narrow or widebody offsets as a guide. Offsets do not change as a result of the conversion.
For my narrow body conversion I used:
Forgeline GA3R wheels: 8.5x19et 51mm (-2mm from OEM) and 12x19et63mm (same as OEM).
Ok, as many of you already know I am not a big fan of the Porsche street-going centerlock wheel set up. While I believe the arrangement is a very slick piece of engineering and the OEM wheels are really quite cool, the additional time, effort, care, and special maintenance to keep them safe and working perfectly is not fitting well with my “track-rat” lifestyle. After well over 60 full wheel and tire changes (yep, all four wheels!), investing in the proper tools and an extra set of wheels, and following the past and current Porsche guidelines to the letter, I have had enough!!!!
It is interesting to note that the “Centerlock Wheel Failure” thread of early this week has had absolutely nothing to do with my decision. In fact, I have been working on a plan to convert my car back to a 5 lug configuration for a few months. Yep, I am going back to the old fashioned 5 lugs!!! Shameless Plug: “PM” me if you would like to purchase my perfect condition, narrow body GT3 OEM CL Wheels.
The good news is that I have cracked the case of the Porsche Centerlock to 5 lug conversion after quite a bit of research/detailed detective work and will test the procedure later next week. I will post photos of the procedure here in this Rennlist Forum as a “Public Service Announcement” for all to see. Special Thanks go to: Steven Tory (“Trophy”), Pete Hitesman (“Savyboy”), John ? (911Slow), Jess Lattin (Porsche Master Tech), Ric Knab (Suncoast Porsche), and David Schardt (Forgeline).
If you have centerlock wheels on your car, don’t despair, this system works fine and Porsche will likely report on the one isolated failure, and hopefully the answer will show up on the “CL Failure” Rennlist thread. The 5 lug conversion described here will likely only be considered for those “track-rats” like myself who gobble up track events a rate of 10 or more days per year.
So without further ado, here is a listing and cost of the Porsche OEM parts required for the 5 lug conversion and brief description of the work that will need to be done.
Front:
997-341-605-01 WHEEL HUB, 2 required, $326.80ea (Suncoast)
999-053-054-06 WHEEL BEARING, 2 required, $88.70ea (Suncoast)
Rear:
997-331-605-00 WHEEL HUB, 2 required, $ 359.32ea (Suncoast)
999-053-055-02 WHEEL BEARING, 2 required, $113.49ea (Suncoast)
Additional Parts:
Porsche Lug bolts, 20 required, $7.43ea (Suncoast)
or
Race Studs: $91/set and Nuts: $77 (2 sets, cone-type and rounded Porsche-Type, best to have both types)
(see Track Studs by APEX: http://www.race-studs.com/servlet/th...Nose%27/Detail )
Total Parts cost with Race Stud upgrade: $1954.62
(Of course this does not include the cost of a new set of wheels,…..or the required labor!)
After my original research was complete I figured that one had to only switch out the Hubs and upgrade to race quality stubs/nuts for the perfect conversion as I found during my research that all nuts and axles are fully compatible. However, this was not exactly the case as it was pointed out by Steven Tory that the Hubs would need to be pressed out of the front and rear wheel carriers destroying the (perfectly good) wheel bearings in the process. Thus new wheel bearings are required all round. The reason for this is that the hubs (CL or 5 lug) fit in to the bearings with an “interference fit” and must be pressed in and out of place. The only bad news is that more labor is required to accomplish the conversion than originally thought, as one must remove the wheel carrier from the car to accomplish the R&R of the CL hub/bearing/5-lug hub. This work is likely best done by a Porsche Dealer as it requires a suitable hydraulic press and accompanying tools, as pointed out by Jess Lattin. Also, the bearings must be installed in the correct orientation, magnetic side in, but this can easily be determined with a paperclip.
Anyway, this is the route I plan to follow. I will report back soon with some comments and photos of the procedure. Hopefully, now there is an alternative to just complaining about the CL wheels, and that Porsche AG will take our opinions into account when designing the next 991 GT cars.
Please, how about a choice next time around?
Cheers!
Doug N.
PS. 911SLOW, can you -re-post the PET figures of the front and rear wheel carriers in this thread along with the associated parts and numbers, so the guys can see. Also, please up my "photo" upload albilities....I've got no space left and I will need some more. Thx!
Old 08-19-2011, 11:29 PM
aussie jimmy
aussie jimmy's Avatar
you have to become an addict now that you're a self-confessed "track-rat"!
Old 08-20-2011, 12:27 AM
P.J.S.
P.J.S.'s Avatar
You will increase the value of your car by at least as much as you spend on parts and labor...
I smell a suncoast kit coming on :-)
Old 08-20-2011, 12:32 AM
tcsracing1
tcsracing1's Avatar
would this be the same route that grand-am cup cars use. more less....?
fun upgrade.
Old 08-20-2011, 12:34 AM
ATL Fahrer
ATL Fahrer's Avatar
Thread subscribed
Old 08-20-2011, 12:40 AM
LehmanZ06
LehmanZ06's Avatar
Center Locks are unique. Kinda cool....and a bit of a pain.
I think you would take a big hit in resale value by doing this.
But it's what you want.
Good Luck
Old 08-20-2011, 12:43 AM
P.J.S.
P.J.S.'s Avatar
I would pay more for it if I was in the market
Old 08-20-2011, 12:47 AM
tcsracing1
tcsracing1's Avatar
Good Luck
Since the majority of parts used in the swap are factory Porsche parts and the Centerlock equipment can be packaged and placed in storage, it could keep full resale value as swapping back is alway possible. ( keeping the centerlock wheels in storage and not selling them would also be neccessary).
good point to mention however. Some dealers would not want all the boxes with the car on a trade in.
Old 08-20-2011, 12:54 AM
Polarporsche
Polarporsche's Avatar
Doug, will you have the 5 bolts ready in time for MMP or still running the CL wheels. I'm sticking with my CL set up but interested in your project.
Cheers
Old 08-20-2011, 01:19 AM
jenk12m
jenk12m's Avatar
cant wait to see how it turns out. big props to you for going forward with it
Old 08-20-2011, 01:37 AM
Larry Cable
Larry Cable's Avatar
Received 3,446 Likes on 2,252 Posts
doug for lifetime membership!
Old 08-20-2011, 02:15 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
can't wait to see.
for most track guys, they will pay more for your mod. i know i would.
once you get it to work, i am certain that suncoast will do a "kit"
Old 08-20-2011, 02:16 AM
1198r
1198r's Avatar
Just out of interest did you consider Carrera GT system as well?
Old 08-20-2011, 02:20 AM
mooty
mooty's Avatar
i htink the wheel choices are highly limited.
on that note, someone might try the cup car CL route? a few more choices in wheels, but still needs special tools though.
Old 08-20-2011, 02:27 AM
DJN
DJN's Avatar
Gents, thank you for the encouragement!
Good Luck
No worries.....I will be buried in this car!
Cheers
Russ, I should have it all done by then and will keep you informed.
I didn't consider it......mostly because I was tried of carrying that "Mother" of a torque wrench around. She's a biggie!
Cheers!
Doug N.
Quick Reply: Centerlocks - I'm out! ....Hello 5-lug conversion!
