Okay, so I finally got the tire trailer.
#32
Maiden voyage under my ownership was last weekend. Trailer was great. Weather sucked. On the bright side, I arrived to late to get a garage and the trailer kept all my gear in the paddock dry.
Only two issues so far. Previous owner had a 997 with side exhausts. I think I managed to melt some of my trailer brake wire cabling with the center exhaust. It still works, but some sort of thermal reinforcement is in order.
Second. 997S wheels are apparently much narrower than GT3 wheels. He had a chock that allowed him to fit four wheels/tires across. I can only do 3. Which creates a problem itself as there's too much space left over and the wheels don't support each other to stand up. There's enough room to lay 2 flat and lean the other two against them, but takes up way too much real estate and becomes a game of tetris when loading the trailer with the jack, tools, and goped. Got to have the goped
#34
Bringing this back from the dead-
I'm installing a hitch on my GT2... It's a hidden hitch with a 2" receiver mounted behind the license plate, completely hidden if the shank is not in. I'll be towing an Aluma AE46 custom made to 31" interior height. I should be able to put a set of wheels/tires in there no problem, standing up, along with a jack, stands, some chairs, and maybe even an EZ up.
Comments?
Comments?
#36
That Aluma is a very cool trailer, was not aware of it. For a tow behind I think that is the ideal size as it limits (good thing) what you can put in it and I like the deck with rail for strapping items or serving as picnic table. Enjoy
#37
Where do you put the goped, cooler full of beer, compressed air tank, box of dirty magazines, etc?
Just make sure it's wide enough to put a set of "widish" wheels in there, side by side across the back. You'll get the most room that way. Mine isn't wide enough so I have to stack 3 tall with tie downs, and one on the floor. I do stack them all the way back over the axle to keep the tongue weight to a min.
Looks cool. I like the design. How much?
#38
Haha...
Road America makes you pay a fee for non-street licensed vehicles, so no goped. Hell, no bicycle! Beer is for the Osthoff or Buck's (or someone else's). And compressed air tank should fit in there.
The issue with the wide wheels- I did think about that- wheels upright, paired up, and strapped individually should leave me 1/2 the trailer for anything else I want to bring. I don't want to bring the kitchen sink- I do enough of that with karting and DE is just for fun... The price is rather steep for a DE trailer, $3400, but for me it's pretty close to what I want in a tag along for the Porsche. The aluminum structure is worth it since weight is a premium on these bumpers. I live in the city (Chicago much of the time) and have nowhere for an enclosed trailer and dedicated truck. That'll change once I get my family moved down to FLA permanently, but for now this is what I've got to do.
#39
So you can get 4 tires across, standing up in the back? Ideally, you could put chocks on the floor and roll them in and out without straps. That's how the previous owner of my trailer did. However, my wheels are 3-4" wider than his, so I was pretty disappointed that didn't work for me.
How much does the trailer weigh?
#41
That is a cool looking trailer for the track!
DD....you drink other peoples beer.
#42
The better question is, are you out of your mind for not pulling a trailer with your GT3? If a honda civic can pull a 3 seater jet ski, a 400hp porsche should be able to haul a tire trailer.
I have been known to tap into other people's adult beverages. I did bring a case to the 48 hours though. If you'd quit avoiding every event we go to you'd know that
#43
@ Nick. Tell me more about the hitch. Is it a wilwood? Despite what people will tell you, there are some points that need to be reinforced.
#44
Don't fret about those who complain about you using a trailer- it's your car and you do with it what you will. I'm not too sure you want to put as much in the trailer as you do, but I think anything under 700lbs total should be fine (so you're normal load you carry would be just outside what I would consider).
#45
I kid about what I put it in. Generally 4 track wheels/tire, tools, spare brake pads, jack, impact driver, go ped, and a 1 gallon can of premix for the go ped. Got to have the go ped
I have a one off hitch setup using the bumper from a 996. Long story... My hitch doesn't seem as elegent as yours as I never take mine off. Too much work....
With that being said, there is a weak both with all our setups. There are aluminum tubes that connect the metal bumper to the chassis. They are very weak and appear to be spot welded. They are strong enough to keep the bumper on but don't appear to be designed to support a pulling motion. I already had one crack and luckily the other one held. Could have been ugly. My shop's solution was to take the tube out on each side and weld metal strips inside to give it significantly more strength. I wouldn't start towing till you get that done... Once you see the bumper off you'll see exactly what I'm talking about.
