997 GT2/GT3 Forum 2005-2012
Has any 997.2 GT3's had coolant failures?
Old 11-09-2011, 09:42 PM
The Greek
The Greek's Avatar
Default Has any 997.2 GT3's had coolant failures?
I was just wondering if any 997.2 GT3's have had coolant failures. I know there were various failures on 07-08 models, but dont recall hearing any new model failures.
Just curious, thats all....
Old 11-09-2011, 09:54 PM
Izzone
Izzone's Avatar
It will happen, if it hasn't
Old 11-09-2011, 11:48 PM
savyboy
savyboy's Avatar
Haven't heard of one (yet).
Old 11-10-2011, 12:30 AM
ChrisF
ChrisF's Avatar
IIRC either Kyrocks or another red .2 owner lost a pipe at around 2k miles. Pretty sure the owner is a regular track rat. It was enough for me to swap to water wetter.
Old 11-10-2011, 12:34 AM
mdrums
mdrums's Avatar
Use water and water wetter so you don't mess up the track.
Old 11-10-2011, 12:10 PM
The Greek
The Greek's Avatar
Just blindly optimistic that even though Porsche hasn't recognized the coolant problem, they somewhere maybe made a little adjustment for the new motors.
Mike, from what I read, water wetter is obviously safer, but voids warranty for the motor. In the event of a coolant failure, good luck getting it covered if they discover water wetter....
Old 11-10-2011, 01:26 PM
996FLT6
996FLT6's Avatar
^ u know if u still running coolant and it let's go you're car will snap wo even a chance of catching it and u hit a wall(check out rl 6gt3 post "coolant failures" there's a video). Who cares about warranty at that point. U lose out on resale value and so will the other cars behind u. Mike
Old 11-10-2011, 02:48 PM
SH || NC
SH || NC's Avatar
See the stickied thread at the top of this forum.
Old 11-10-2011, 03:50 PM
micahbones
micahbones's Avatar
Word. I also do not see how the engine warranty would be void given that water wetter cools at least as effectively as coolant/antifreeze, and if you blow a coolant fitting much of your coolant is gone anyway. Only disadvantage of H20 + water wetter is it can freeze if the car is stored in below-freezing temps.
Old 11-10-2011, 05:21 PM
The Greek
The Greek's Avatar
^ I know the realistic reasons why water wetter would never damage a motor, but when has dealers ever made sense about warranties. Porsche officials made it painfully clear that if they saw water wetter in a coolant failure motor, warranty would be void end of story....
Old 11-10-2011, 05:33 PM
ChrisF
ChrisF's Avatar
What is the basis for "Porsche officials made it painfully clear..."? If the coolant line lets go and dumps, there will be no coolant left to examine. Also, if the motor throws a rod or internally lets go, I'd love to see them argue/prove that water wetter was the cause.
Old 11-10-2011, 07:28 PM
sharkster
sharkster's Avatar
I know of two locally yup
Old 11-10-2011, 09:34 PM
The Greek
The Greek's Avatar
Chris, water wetter is pink. Trust me, they know if you used Water Wetter. Coolant failures dont typically caused engine failures, although they can if you keep driving. Would be a long suck filled fight with them saying wetter caused line to burst.
Sharky, I had a minute of hope from not hearing of any 997.2 failures. Thank you for absolutely crushing that feeling.... Damn you
Old 11-10-2011, 10:26 PM
fjpdds
fjpdds's Avatar
Mine shows: Below minimum, is this a sign of trouble starting?
Old 11-10-2011, 10:32 PM
911rox
911rox's Avatar
Possibly a slow leak somewhere but not a fitting failure... They usually just let go and you get a rapid coolant dump.... May be worth getting it checked at the dealer as you're obviously still under warranty.
Quick Reply: Has any 997.2 GT3's had coolant failures?
