997 GT2/GT3 Forum 2005-2012
Starter Motor Relay
Old 12-12-2011, 12:53 PM
Candellara
Candellara's Avatar
Default Starter Motor Relay
Guys,
I am getting an intermittment non start "click" about 1 in 10 times on trying to start the car.
Been told by OPC that it's a strong likelood that it's the starter motor relay.
Whereabouts is this located?
Cheers
Old 12-14-2011, 12:37 PM
Nizer
Nizer's Avatar
Received 1,736 Likes on 919 Posts
Warning! This is a voodoo post. My car just started doing the same thing after reading this email.
Old 12-15-2011, 05:19 AM
Candellara
Candellara's Avatar
Sorry mate.
Apparently it's quite a common issue. Loads of posts on varying forums about this issue, but no one has posted a resolve of the problem
It would seem it could be the following:
Clutch switch - mine's ok
Dead cell in battery?
Intermittent Starter Motor problem?
Starter Motor Relay?
HELP!!
Old 12-15-2011, 08:10 AM
Nizer
Nizer's Avatar
Was the tech not able to resolve your issue or have you not taken it in yet for repair?
Old 12-15-2011, 08:56 AM
Candellara
Candellara's Avatar
No, haven't taken it in, as it only happens intermittently.
Battery is obviously nearly 5 years old, so thought i'd change this and the simple stuff such as the relay before i committ to spending money at OPC for investigation
Old 12-15-2011, 01:36 PM
SH || NC
SH || NC's Avatar
Check the ground strap; make sure the nut is tight. On the 6-3 its near the rear muffler, frame rail, passenger side (link)
Old 12-16-2011, 04:41 AM
Candellara
Candellara's Avatar
Any ideas on the 7-3? or same place?
Old 01-11-2012, 10:32 PM
Nizer
Nizer's Avatar
So just got car back. Turns out it was a bad starter motor. Replaced under warranty. Apparently they've had a few.
Quick Reply: Starter Motor Relay
