997 GT2/GT3 Forum 2005-2012
18" wheels to clear 380mm brakes
Old 03-13-2014, 11:54 AM
RedRSA
RedRSA's Avatar
Default 18" wheels to clear 380mm brakes
Starting new thread...combines elements of other, very long, threads.
I prefer to use 18's for the track. However, I am extremely particular and I'm having unexpected difficulties finding a solution I like.
I have a 2010 GT3 that I have converted to 5-lug hubs. I ordered two sets of track wheels in when I bought the car in January and they do not fit, dammit! (still fighting with company at this point, will reveal when appropriate) The fronts were too wide (their 9" wheel actually measures 9 1/4"), and the inner diameter of the inner barrel contacts the caliper. Scraped the paint off the calipers in two places when test fitting. Recall that in the 997.2 the steel rotors and calipers are the same 380mm size as all 997 PCCB's.
It appears that mono block wheels provide the possibility of more room. Candidates include:
(1) CCW C10: least expensive, quicker to get, responsive customer support; butt fugly, heavy, tires tend rotate on them, and weights don't stick well.
(2) BBS Model?: expensive, have a few in stock, but may take long to get the others, painted not anodized.
(3) Forgeline GA1R: expensive, look difficult to keep clean, painted not anodized, take four+ weeks to make.
Interested in input and recommendations based on experience using any of these, thank you.
Blasted wheels; the one thing I took for granted that they would fit; now it is costing me track time and I am missing events...
Old 03-13-2014, 12:00 PM
kosmo
kosmo's Avatar
i have CCW C10 in "peened titanium". The 18x9 clear, barely
there are some BBS floating around. Try Mooty!
Old 03-13-2014, 12:02 PM
P.J.S.
P.J.S.'s Avatar
Finspeed, Jongbloed, fikse, BBS, hre, etc
Old 03-13-2014, 12:14 PM
rnh204
rnh204's Avatar
I recently converted myself to 5 lug too - wasn't planning to do it so soon but I got a killer deal on a used set of GA3R's in GT2.
Old 03-13-2014, 12:26 PM
RedRSA
RedRSA's Avatar
Thanks; at least they do clear. Have you had any issues with Hoosiers rotating on the rims! or with having weight stay on?
I think the BBS's floating around were centerlock.
Originally Posted by kosmo
i have CCW C10 in "peened titanium". The 18x9 clear, barely. there are some BBS floating around. Try Mooty!
Old 03-13-2014, 12:28 PM
RedRSA
RedRSA's Avatar
Congrats. Do the GA3R's clear the calipers, and by how much?
Old 03-13-2014, 12:29 PM
P.J.S.
P.J.S.'s Avatar
to be fair -- the clearance on any 18" wheel over 380mm brakes is pretty tight... but they clear
Old 03-13-2014, 12:30 PM
RedRSA
RedRSA's Avatar
Had not investigated Finspeed; look nice, though expensive. Worth a call.
paver
paver's Avatar
I'm happy with finspeed. Have a knurled beadseat option and they clear the brakes. They made 18" for me that clear 390mm discs. So they can get you extra clearance if you want it.
Old 03-13-2014, 12:31 PM
RedRSA
RedRSA's Avatar
Indeed; some clear by few thousandths of an inch.
Old 03-13-2014, 12:57 PM
kosmo
kosmo's Avatar
I run nittos, so i cant say, plus Im not that fast!
weights seem ok
Old 03-13-2014, 01:02 PM
RedRSA
RedRSA's Avatar
Good to hear, thank you. I hadn't hear of fin speed before; they must be relatively new. Very good that they can make adjustments to clear 390mm discs; that would give me plenty of margin.
Are you using 9x18 fronts? What offsets? The tires (I use 245 Hoosiers) clear the spring on the inside and the fender on the outside?
Old 03-13-2014, 01:07 PM
kosmo
kosmo's Avatar
i dont think CCW uses offsets but here spec
BS: 7.0
PCD: 5X130
CB: 2.82
Old 03-13-2014, 01:15 PM
paver
paver's Avatar
They are relatively new. I actually met Daniel(the owner) and Mitchell, the chief engineer when I was at COTA last month. They took time to give me a lot of info. I trust them. I believe he will stand behind his product.
Yes, 9x18 fronts. I can't remember exactly, but the offset is around 48 to 50.
FWIW, the Finspeed 18" clears the 390mm discs more than the OZ 18" I had before clears the 380mm rotor.
This is how much the OZ cleared. Finspeed is more than that over the bigger disc.
Old 03-13-2014, 01:22 PM
paver
paver's Avatar
crappy pic but this is 18"x 9" F11 with the extra light option
Quick Reply: 18" wheels to clear 380mm brakes
