Current tire thinking
^^^ That's them. Prices went down again. They were 1044, went up to nearly 1200, now back down to 1100.
I've switched from the NT01 245/305s to the 275/335s. Easily 1.5 seconds quicker on a 2 minute lap and actually easier to drive at the limit. I get about 12-15 HC on a smooth track before they're done..
i know i can get a 335 under my rear as I've had one back there.
but the 265 front... are you running wide fenders?
When you say done, you're cording them in 12-15 cycles? You got a LOT more power than us lowly N/A guys :-)
335/30 NT01 at 15 cycles
[url=https://flic.kr/p/LHFBRW]
18x10x13 275/335 fitment
[url=https://flic.kr/p/KbY8RS]
[url=https://flic.kr/p/LFwuP9]
That is impressive. I only have 18x9 and 18x12 wheels though probably not enough to support the 275/335 combo even if I can stuff them in there.
9.5/12.5 would be the minimum for the 275/335s. Tires would be severely pinched on 9/12s. I tried that when I was doing measurements with the tires to calculate the proper offsets for the wider wheels. You are adding over 1" of extra width per corner so you need the wider wheels. The performance increase is impressive and well worth it however.
ok thanks for the pics and description. I would need to change my setup as right now I have the cup lower inner links up front to widen the track so wider lower, strut mounts rotated, and tops pulled out to about -3 or so camber today (SOMETHING LIKE THAT).
The issue I have is the outer edge is literally a butt hair away from rubbing. The inner I went to a much smaller diameter spring (ohlins) for clearance on a 9" wheel, could probably go with a 9.5" and fit.
Like the idea of more grip :-) Need to get up under there with my chassis guy and take a look.
Shows the art of the setup. Will it fit? sure, with the right setup! :-)
Not the best pic but you can see how close I'm at w current setup
Looking at your pics, clearances are very similar as what I'm running. Tight as hell. In a nutshell, everything needs to be pushed into the wheel well to make the wide stuff work. I suspect that if you look at the clearance between your wheel and the springs, you'll see that you have a lot of clearance with 9s. Your car looks great btw...
The first time I drove the 275/335 set up, I realized this is the way the car should have been set up from the start. The difference is staggering...
Here is the tire comparison:
245/40 v. 275/35
[url=https://flic.kr/p/Fx5Gkj]
305/35 v. 335/30
[url=https://flic.kr/p/F7Pkpj]
245/40 v. 275/35
305/35 v. 335/30
Holy crap that is WAY more front tire. Is the car just stuck to the ground with the 275/335 setup? Do you get any under/oversteer at all when you don't overdrive the car?
One of the interesting things with the NT01 275/335s is that they are quick right out of the box while the 245/305s were very greasy new and took 2-3 sessions to get optimum grip. Can't explain that one...
