997 GT2/GT3 Forum 2005-2012
Brake Condition 997.2 GT3 - opinions please!
Old 04-10-2017, 12:28 PM
DK7
DK7's Avatar
Default Brake Condition 997.2 GT3 - opinions please!
Hi guys,
my rotors have some crackes.
Do you think i should use the brake even longer? How much further life is possible..?
Thanks.
Old 04-10-2017, 01:53 PM
ilko
Agent Orange
ilko's Avatar
Rotors are toast. Cracks are bad (but OK for a few more miles of street driving). The bigger problem is the large lip at the outer edge of the rotor. It means that the rotor is likely below minimum thickness at this point. Pads look OK.
Old 04-10-2017, 03:04 PM
DK7
DK7's Avatar
Thank you. A pity. I thought I can do 2-3 trackdays...
The lip at the outer edge of the rotor "looks" on the picture a little bit more than real.
Old 04-10-2017, 03:43 PM
boostedt0y
boostedt0y's Avatar
Yep looks toast to me. I have some OEM rotors with less than 3k miles I'd sell cheap. If interested PM me.
Old 04-10-2017, 07:26 PM
rbahr
rbahr's Avatar
I guess I am gonna take a contrarian view here. Those small heat check cracks are fine - it is when the cracks make it to the edge of the disk that they are officially junk... I run stuff like this all the time and have yet to have a problem.
Ray
Old 04-10-2017, 07:30 PM
boostedt0y
boostedt0y's Avatar
Ray
The cracks are fine. As you mentioned, its when the cracks make it to the edge of the rotor is when they are really a problem.
The issue with OP rotors is not the cracks, but that the rotor is likely below minimum thickness due to the significant "lippage" on the rotor. Best way to confirm is to grab a caliper and measure rotor thickness.
Old 04-10-2017, 07:59 PM
Fisher
Fisher's Avatar
A bit of preventative maintenance could be used to reduce the rotor deterioration. Cleaning the holes is a start.
I have been told the following:
"The drilled holes on a brake rotor make it easier for heat, gas and water to be moved away from the rotor surface, helping to keep the brake performance strong."
Old 04-10-2017, 09:07 PM
Dr.Porsche
Dr.Porsche's Avatar
I'll chime in here as well. Cracks are fine. Can't tell about the lip, but the cracks are not a concern unless they go to the edge or connect the dots.
Old 04-10-2017, 10:09 PM
ranger22
ranger22's Avatar
Rotors look fine me to. You can have many more track days out of those.
Old 04-10-2017, 10:11 PM
AGO
AGO's Avatar
I've driven with that rotor condition at the end of their life when I was starting. I'd suggest if tracking to be mindful of brake requirements of the specific track you would run, and also related to your speed/run group...
In you are in doubt, swap them ... those rotors have given plenty of track fun !
Old 04-11-2017, 12:08 AM
rbahr
rbahr's Avatar
As far as the lip - I thought I saw one - was not sure - just measure it...
I generally will go with slots over holes anytime - brakes are all about thermal mass, the more the better...
Anyway @ 400-500 deg f water does not last long in a liquid state, current pads don't really outgass much (after they are bedded in), the rumor is that the real Porsche rotors are cast with the holes as opposed to drilled - helps with internal stress...
So, if the rotor measures ok, pads are ok, you still have life - BUT keep an eye on the cracks ...
Ray
Old 04-11-2017, 07:05 AM
DK7
DK7's Avatar
Here you can say the outer edge better.
Old 04-11-2017, 07:09 AM
DK7
DK7's Avatar
Old 04-11-2017, 08:15 AM
rbahr
rbahr's Avatar
Those are getting a bit worn and I would measure them, but it still looks like there is life in them esp if this is primarily for street use.
Ray
Old 04-11-2017, 10:31 PM
Rob996
Rob996's Avatar
For those wanting an idea of totally toasted rotors.
Quick Reply: Brake Condition 997.2 GT3 - opinions please!
