997 Turbo Forum 2005-2012
Spoiler goes up after 75mph but come down
Old 01-23-2019, 04:01 PM
welder.mark
welder.mark's Avatar
Default Spoiler goes up after 75mph but come down
Last three times out ,opening it up , spoiler will go up but when I slow down , warning comes on and spoiler won't drop down. Will engage spoiler button and spoiler won't do anything. Stop,turn off car,restart and engage spoiler button and the spoiler will go up and down on command. Need advice on solution. Thank you ,Mark
Old 01-23-2019, 04:17 PM
mffarrell
mffarrell's Avatar
It could be a bad spoiler relay switch.
Old 01-23-2019, 04:20 PM
welder.mark
Will check this out, thank you!
Old 01-23-2019, 04:33 PM
mffarrell
mffarrell's Avatar
There are two relays, up and down.
Aaron12 (03-01-2023)
Old 01-23-2019, 07:21 PM
saabin
saabin's Avatar
^ Where is this relay box? I haven't seen it before..
Old 01-24-2019, 02:42 PM
welder.mark
Is this the same as the 997 turbo wing? Thank you. Advance!!
Old 01-25-2019, 07:30 AM
RennKit-Dave
Basic Sponsor
RennKit-Dave's Avatar
yes, same systems. The console switch is the only difference I’ve found.
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
  • Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
  • Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
  • AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
Old 01-29-2019, 04:17 PM
welder.mark
Unbelievable! Had to go to Corpus Christi for a funeral from Roswell New Mexico, went over 75 a couple of times. Stopped lowered the spoiler because of warning inoperable then spent the night in San Antonio and now the spoiler has been working fine ever since! No warning ,drove 85 all the way home , took it out this morning and everything is clicking! Go figure??!!
Old 01-29-2019, 05:48 PM
mffarrell
mffarrell's Avatar
Gremlins?
Old 01-29-2019, 06:30 PM
TT Surgeon
TT Surgeon's Avatar
Probably the microseitches
unfortunately you have to replace the harness, not just the Ms like a 996.
Old 01-29-2019, 07:39 PM
lliejk
lliejk's Avatar
You can't splice them in? I haven't looked at what I am facing yet. Purchased the car with an inoperable wing. Don't know if the pump is toast, leaking cylinders, bad micro switches or what.
Should be fun!
Ed
Old 01-29-2019, 09:04 PM
RennKit-Dave
Basic Sponsor
Wink
That explains it. No spoiler system works correctly in Roswell due to residual EMF effects.
Old 01-30-2019, 08:04 AM
Cosmo Kramer
Cosmo Kramer's Avatar
Mine does this intermittently as well, no retraction and no warnings. Hydraulics are dry and look perfect. I was told its probably the micro-switches.
Old 01-30-2019, 12:22 PM
dprantl
dprantl's Avatar
On my old 996TT the top passenger microswitch connector somehow had a tiny bit of play in it, causing it to break its internal connection from time to time. This is the type of switch that has springs in it so it is constantly trying to pry itself apart and the housing is held together by two small plastic clips, one on each side. The symptoms were that the wing would rise fine, but throw an error at the top. Taking the cover off and pressing the microswitch together would make the problem go away for a while, so I eventually wrapped it with tape and the problem never came back.
Dan
Old 01-30-2019, 01:05 PM
Brainz
Brainz's Avatar
But for turning truck traffic on 285, I'd have guessed you were never less than 75 on that drive. And from Fort Stockton to Kerrville, you could have easily averaged well into the triple digits (assuming it wasn't too windy). That's no-man's land (except lots and lots of oilfield trucks)!
Quick Reply: Spoiler goes up after 75mph but come down
