Coilovers
Coilovers
I’m having quite a journey with my 997tt suspension. I bought it lowered with H&R coilovers. I had suspension replaced with OEM because the ride was way too harsh. I bought the OEM suspension used. Two weeks later, the front passenger strut broke. Now I’m back to researching what to buy. I do not track the car and am looking for a comfortable ride. I decided after so much scraping and “crashing” over bumps from my H&R lowered suspension, I do not want it lowered again. I bought a DSC module when I had the OEM suspension installed and would like to continue using. Are Bilstein’s the only suspension that I can use to retain PASM?
Those or splashing out for the Tractive shocks. You can get B6 shocks and reuse the OEM springs.
Just buy new OEM struts (B4 I believe) and use stock springs. That plus the DSC module will give you the most comfort. A more aggressive alignment will do wonders for the handling characteristics.
Link to my other thread:
https://rennlist.com/forums/997-turb...ould-care.html
My current setup:
50nm front springs == 286lbs
90nm rear springs == 514lbs
Previously tech art lowering springs were on the car, I have opted for a .25" ride height INCREASE from the techart ride height.
Shocks/Dampers valved for significant blowoff behavior at the 3-5 inch per second speeds. The force build up is gradual and never more than ~55% of critical damping ((cc=critical damping = ~77lbs per inch) I do not know the exact curb weight, sprung, and unsprung mass so I am making some guesstimates.
And completely chew up tires more quickly and unnecessarily if it is mainly street driven.
Originally Posted by ShatterPoints
...And completely chew up tires more quickly and unnecessarily if it is mainly street driven.
samiam21 (10-25-2022)
Bilsteins are OE and aside from TPC's tractive product its pretty much the only one you can use with PASM. You are right to look at the dampers first in order to address the harshness. You would also want to look at bump stops (softer materials relax the travel more progressively instead of the quick infinite rate harder bump stops exhibit). If you like I can refer you to the suspension builder I used to completely revalve the H&R coilover and we went with softer springs. (special note, H&R coilovers are spec made bilsteins with an H&R sticker on them). I have a thread I did about my experience and I should be getting the car back from the shop friday to write my second part of the experience + lessons learned over the weekend. Do you have a budget you're sticking to?
My current setup:
My current setup:
As long as you keep the toe minimal it should be ok. More negative camber will increase wear on the inside (and decrease it on the outside) slightly, but you should still get comparable mileage out of it. It tends to look worse than it is, because the outside will still have lots of life when the inside is toast, but if you actually look at how many miles out get out of the tire it shouldn't be that much less than when you're wearing it evenly. Again, given zero toe.
Former Vendor
We love Öhlins and have good luck with them on all platforms. It's not PASM compatible though so we either run the cancellation kit or remove the PASM in PIWIS. 997TT is a stocking item. For the price you just can't go wrong. If that's an option feel free to email or PM for more detail.
My DSC Tractive Coilovers arrive this Friday the 5th, they are compatible with PASM. Also ordered their adjustable sway bars, front and rear.. I already have their controller, so that also gets an upgraded program with the new suspension. Can't wait to feel the difference.
Bruce in Arizona
Bruce in Arizona
Bruce in Arizona
Bruce in Arizona
Most Turbo owners put so few miles on their cars that tire wear is not a huge issue. I put about 3k miles / yr on my car and with -1.9 front and -1.7 rear and current wear rates my tires will last at least 3 years. It’s a great compromise of comfort and handling. What you are doing is impressive and very detailed but I suspect that most owners (OP included) want a simpler solution.
For instance I can say that if not all, then almost all aftermarket dampers use too much damping force and NONE of them except for Ohlins even discusses road filtering or strategies to achieve both comfort and performance. What I would have to say based on what I have learned is in contradiction to major brand manufacturers but only with regards to use cases. In otherwords the aftermarket options are technically valid because they mostly copy the OEM performance profile and then alter it without telling you what or why. So while I appreciate that most people want simple straight forward solutions, I am presuming that you will want to know the "why" especially if on the surface its appears contradictory.
Tractive System by TCP Racing with new sway bars and all new sport links and bushings and upgraded DCS program for the new system. Drove over the weekend. Told there is a 100 mile + break in period. I have noticed a softer, smoother ride as the miles increase. The feel reminds me of my GT4 handling. Gives tremendous confidence in corners and hard braking. Because the car remains so flat, it more and more feels like I am in control of the movement of the car, not the corners and curves. Because you can carry a higher safe speed into the curves, you do. I know what this will do to my tire wear, It has transformed the handling of the car. While it was expensive, what I have done is created a different car, so it makes the price worth having a entirely new car to drive. I want to thank Tom at DSC/TPC Racing. He seemed happy to answer my many questions and was willing to education me along the way. Truly a top professional organization. I will provide further updates.
Bruce in Arizona
997.2 Turbo
Bruce in Arizona
997.2 Turbo
Bruce in Arizona
997.2 Turbo
Bruce in Arizona
997.2 Turbo
Just thought I would update this post with what I ended up doing. I bought Bilstein B4 (fronts), new springs, bushings and top mounts. I couldn’t get the rears. As soon as they become available, I’ll buy and install them. I have to say, I’m very impressed. It feels and rides like a new vehicle. Very composed, planted and firm but not harsh. Definitely doesn’t feel like a 2008. This has to be the most solid platform out there.
