FS: DSC Tractive coilovers
I had these on my 2011 Turbo S for 2 years and about 10K mi. Street and autocross use only, no trackdays. 400lb front springs, 700lb. rear. More info can be found on DSC's website, and here's the ad in the Marketplace.
@larsondo it’s subjective, but the main difference is having solid top mounts vs stock, so you can get more road noise on certain surfaces. The springs are a lot stiffer than stock, but the shocks and programming of the controller compensate a lot for that making for a nice ride. The best way I can reference the overall feel, is that it makes a turbo feel like a GT3, but you have the additional advantage of the two shock profiles to run just by pressing the button. A comfy mode, and a “track” mode.
@tonupbklyn yep. I’ll provide the buyer with the file to load onto your controller that DSC make for this particular build, and a couple I make up if you want. You can of course do your own programming.
ideally, to take advantage of the much better damper full range of operating parameters. It’s easy.
all you have to do is open the file that I’ll provide in their program, and load it onto the controller by clicking the “write” function. It actually looks like the same file is available for download on their website.
Are these still available and will they work on a 2007 Turbo? price?
