Black Foam from AC
The vent flap has this foam on it and over time it fails and stars blowing out of the vents. Eventually the air will stop blending cold / hot. There is a fix that people do without taking the whole car apart. There are few videos of people fixing it.
The following 3 users liked this post by tatarin:
The vent flap has this foam on it and over time it fails and stars blowing out of the vents. Eventually the air will stop blending cold / hot. There is a fix that people do without taking the whole car apart. There are few videos of people fixing it. https://www.youtube.com/watch?v=FaKw9BxF49Q.
on the R32 it's quite the job to repair, the blend doors are in the interior behind the dash / radio. the fix usually involves disassembling the entire dash. folks have figured out a way to plug the holes that aren't as invasive since then. glad to see a similar approach exists here.
babylonboots (03-23-2023)
I had this issue with my 997C2S. The dealer quoted me $3500 for the repair. Keep in mind that breathing in the particles is not ideal. I recall using tweezers to get the bigger pieces from at AC vents as it was being expelled. What a pain. If it were a 996 GT3 RS I'd invest in the fix.
I had my blower box and condenser replaced a few years ago. I had the black foam and an a/c leak. It was not a cheap job!! $3200 back in 2021.
Read this thread.
https://rennlist.com/forums/996-foru...ntn-issue.html
I chime in there somewhere how I fixed it on my 997 Turbo. There are 2 flaps, they both need fixing. I got a quote to fix it, and it was over $7k. I fixed it for $10 and an afternoon of time
edit: here are my additions => https://rennlist.com/forums/996-foru...l#post16993139
The following 4 users liked this post by moxie (SF):
defunct_neurons (03-25-2023),
eclou (03-23-2023),
FlatsixS (08-03-2023),
texas_maverick (03-22-2023)
So, based on what I've read, the only economic solution for the 997 is to go in through the frunk. Is that correct? It seems that the 996 method of accessing flaps behind the radio is not an option for the 997.
I'm just trying to decide when to do this. I don't have the heater issue now (I live in S TX), but I do have a bunch of the black foam that hits my brown interior. It is a mess to clean up if you don't get it off the carpet before someone steps on it.
Good luck! It's not that bad of a job
babylonboots (03-25-2023)
Seems we live pretty close "babylonboots". Same problem with mine. Houston weather and moisture is adding to the foam cloud. I used a vacuum with the windshield vents and I think that got most of the pieces of disintegrating foam. Still the condensation is big. I need to tackle the problem soon.
