997 Turbo Forum 2005-2012
Bose/PCM observation...
Old 09-20-2007, 11:03 PM
texas911
texas911's Avatar
Default Bose/PCM observation...
So I tested out my Bose system after a few bashed it as sounding crappy. And you know what, they're right, but only if I play mp3 CD's. If I burn an audio CD of the same songs, the sonic range dramatically improves. I wonder in Porsche cheap-ed out and put crappy D/A for the mp3 player for the PCM. In which case, its not Bose's fault.
Old 09-20-2007, 11:48 PM
george_k
george_k's Avatar
I noticed the same thing, store bought CD's sound much better than homemade MP3's in my Bose system.
Old 10-19-2007, 04:40 AM
2thfixr
2thfixr's Avatar
The Bose system in the 997 cab is much better than the sytem in the coupe as well. The tunnel mounted sub sounds better than the deck mounted unit.
Old 10-19-2007, 08:15 AM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
There are no D/A converters in the audio path contained in the CDR23 and/or PCM.
All content (audio, command and control) is passed over plastic fiber optic (MOST network, ~25Mb/s). Audio DAC's are contained within the amplifier, post DSP/pre output amplifier stage.
I don't quite understand what you mean by 'sonic range', but did you try turning off DSP effects, such as Centerpoint (simulated surround) and/or Audiopilot (vehicle noise cancellation)?
Old 10-20-2007, 01:29 AM
whyb2nd
whyb2nd's Avatar
My burned mp3 cds sound as good as commercial, some times better. I try to use only bit rates over 220.
Old 10-20-2007, 09:21 AM
eclou
eclou's Avatar
Received 1,173 Likes on 577 Posts
I use only CD's burned from iTunes. All my sounds are encoded thru the AAC at 200kb or higher sample rates. I don't consider myself anything near an audiophile, though all my home stereos/AV units are separate components only using moderate amps and pre-amps. I think the Bose system once tweaked is excellent considering the noise of the powertrain and road
Old 10-20-2007, 10:56 AM
texas911
texas911's Avatar
I don't think the speakers can convert mp3 signals to audio without help.
Old 10-20-2007, 02:41 PM
cviles
Unique Title
cviles's Avatar
What bitrate are the MP3s you're playing back encoded at? Higher bitrate = better quality, but bigger files so there's a tradeoff to be made. I encode all mine at 192kb/s and they sound excellent, only slightly off from pre-recorded CD quality.
Old 10-21-2007, 07:59 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Really?
Where did I mention speakers?
Good luck with your problem
Old 10-21-2007, 11:22 PM
whyb2nd
whyb2nd's Avatar
Let me mention I also burn all discs from itunes, not sure if that makes a diff.
Old 10-22-2007, 12:39 AM
ALPINE_997
ALPINE_997's Avatar
I play MP3's all the time and have my setting to simulated surround and it sounds wonderful. I have yet to hear a bad song from my burns. Most of my MP3's are 192bit rate or more.
Old 10-22-2007, 09:45 AM
TestnDoc
TestnDoc's Avatar
My Bose system with MP3s and iPod kicks ***. Sounds great.
Old 10-31-2011, 01:40 AM
BuddyK
BuddyK's Avatar
+1
Old 01-03-2015, 01:02 AM
shadow993
shadow993's Avatar
The stereo guy said my system sounded awesome when he installed the Trnzlt Blue HF
Old 01-03-2015, 05:41 PM
phillipj
phillipj's Avatar
Wow I guess I must be a freak.. My Bose "Plus" Superior whatever is the worst piece of crap I have had in any high end car..
I actually took my car to the dealer to diagnose why it sounded so bad when I got my car.. Dealer said "Nothing wrong with your system..They all sound like that".
My car had a 150k sticker when new.. I couldn't believe Porsche gave this system the green light.. I guess Germans don't think you should be listening to music while driving.
The sensurround is pathetic.. The Bass is horrible.. The speakers have no range whatsoever.. I have the fader almost 80% to the rear just to make it feel i'm not driving an old pick up truck with AM radio.
My wifes system in her Fiat 500 sounds way better than mine. Sad...
Systems in 20k Scions are far superior to that garbage Bose makes for Porsche. I'm used to how bad it is so now it's just normal.. I'm glad everyone else is so happy with theirs.. Like the saying goes "No Highs, No Lows.. Must be Bose....
Quick Reply: Bose/PCM observation...
