Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Turbo Technical Discussion Areas > 997 Turbo Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 02-06-2012, 12:33 PM   #1
DaBrat
User
DaBrat's Avatar
Default Sway Bar Setting
I currently have my sway bars set at medium / medium. I want to get more oversteer. Should I go [medium rear / soft front] or [hard rear / medium front]? Any difference? Thanks!
DaBrat is offline   Reply With Quote
Old 02-28-2012, 09:10 AM   #2
mdrums
mdrums's Avatar
https://www.facebook.com/profile.php?id=1148135094
Softer in front will generally help the front grip more.
What are you alignment specs? Tires?
Mike
2012 Carrera GTS - PDK - Sport PASM - GT2 Sport Buckets - RSS Competition Bar - Schroth Harness - GT3 Cup Front LCA - Tarret Mono Balls - Orbit Custom GTS Sway Bars - OZ Wheels - Race Keeper.
PCA National Instructor #200911210 Chin and PBOC Instructor
mdrums is offline   Reply With Quote
Old 02-28-2012, 09:47 AM   #3
DaBrat
User
DaBrat's Avatar
I'm currently running Pirelli Trofeos. Alignment is stock.
Thanks!
Old 02-28-2012, 10:02 AM   #4
mdrums
mdrums's Avatar
I'm thinking of trying out Trofeo's next....my alignment specs are -2.5 front and -1.9 rear and running Michelin Sport Cups and they seem to need slightly more rear camber than what I'm running as they are rolling over some.
Anyway....from what I see guys running with camber specs like mine are softer front and stiffer rear. So if you add more front camber...I assume stock setting is somewhere around -.5 to -1 on your Turbo....you will get better grip from the front and thus the rear will rotate better. Then you can also soften the front sway a notch and test that for a couple of laps.
From reading about the Trofeo's they want more negitive camber than stock street set up.
Mike
Old 02-29-2012, 12:03 AM   #5
DaBrat
User
DaBrat's Avatar
The Trofeos are awesome! But after reading your post, seems like I gotta do some camber adjustments. I just put on new BBS wheels with new Trofeos and the car sticks to the road to the point that I can't really tell if I still have understeer. I think I'll try to soften the front sway anyway and see how that goes. And while I'm at it, mess with the camber settings. Thanks!
Old 02-29-2012, 09:01 AM   #6
Doc GTO
Doc GTO's Avatar
Quote:
You can do the Tarett camber plates and those give you about 1.1 to 1.5 more negative camber without adding stress to your front axles. If you want more then you need to do the GT3 LCAs and add the 5mm shims. You can dial in -2.5 total with that setup, which is what I'm using.
As far as the sway bar, you can do soft front and med rear or med front and firm rear.
_____________________________________________________
Doc GTO
2007 997 Turbo: Atlas Grey/Stone - GMG WC, Tarett, Fabspeed, Sachs 2.5
Previous P-cars
2005 911S Launch Edition - Blk/Blk/PCCBs
1987 928S4 - GP White/Blue
Doc GTO is offline   Reply With Quote
Old 02-29-2012, 09:23 AM   #7
DaBrat
User
DaBrat's Avatar
I have been considering getting the RSS lower control arms + rear links, however, I'm worried the car will be too harsh for the street. Whatcha think?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
