997 Turbo Forum 2005-2012
Does anyone use anti-seize on their wheel bolts?
Old 09-25-2013, 07:46 PM
9115INGH
9115INGH's Avatar
Default Does anyone use anti-seize on their wheel bolts?
Hey,
Just wondering if anyone uses any kind of anti-sieze on their wheel bolts?
I have some titanium ones and was wondering if it makes any difference to whether i should or not.
KJ
Old 09-25-2013, 07:58 PM
TT Surgeon
TT Surgeon's Avatar
I believe tikore recommends it on ti bolts, not sure if it makes a difference.
Old 09-25-2013, 08:26 PM
jhbrennan
jhbrennan's Avatar
Porsche recommends too.
Old 09-25-2013, 09:14 PM
MLindgren
MLindgren's Avatar
There should be a different torque spec if using anti-seize.
Do titanium lug bolts use the same torque spec as steel to insure proper bolt stretch?
Old 09-25-2013, 09:21 PM
jhbrennan
jhbrennan's Avatar
The owner's manual only lists 1 torque spec which I assumes includes the recommendation to use Optimoly.
Old 09-25-2013, 11:49 PM
ilko
Agent Orange
ilko's Avatar
I've been using white lithium grease on the wheel lugs/bolts on all of my cars for over 10 years. I don't torque them any differently, never had a seized wheel, and have yet to experience a wheel fall off
Old 09-26-2013, 02:06 AM
L_perm
L_perm's Avatar
I use a moly-based anti-seize just as my manual tells me to. I only fully torque the bolts after lowering the wheel to the ground. Yada, yada, yada.
Do I think either of these matter? Not really. Before I bought an expensive car--for me at least--I never used anti-seize, and I tightened as much as seemed necessary using a lug wrench--no torque wrenches involved. Never had any problems of any kind--abnormal tire wear, vibration, seized lug nuts, etc.
My Dad laughs at how I have to pamper my cars these days. He and I both grew up on steel wheels and jacks that you crank up with a lug wrench before you pry off the hubcap and break the lug nuts loose--if you had a hubcap. Some of the old pickup trucks we jacked up by the bumper, IIRC.
And weeeeeee liked it!
Old 09-26-2013, 03:20 AM
Redmist
Redmist's Avatar
Why take a chance? The manual says use anti-sieze. It doesn't take that much effort.
Old 09-26-2013, 05:52 AM
9115INGH
9115INGH's Avatar
This is from the Owners manual guys, Optimoly TA is the way to go :
Old 09-26-2013, 09:14 AM
4ocious
4ocious's Avatar
Good info and timely! Swapping my Turbo II wheels out for my GT3 RS wheels on Friday. I'll follow the recommendations. Thanks.
Old 09-26-2013, 09:52 AM
Metal Guru
Metal Guru's Avatar
Originally Posted by L_perm
I
The issue is dissimilar materials and galling.
If your torquing up a steel lug to a steel wheel, no issues. Tightening up a "dry" aluminum fastener to a steel stud could result in galling which will seize the aluminum fastener. Sod's Law dictates that you will discover this when you get a flat tire on a dark, rainy night miles from civilization
Old 09-27-2013, 01:21 AM
L_perm
L_perm's Avatar
Ha! Good point--dissimilar metals doing their chemical shenanigans. I guess back when we were using dry nuts and lug wrenches we didn't have any of those fancy new metals like aluminum on our wheels.
Quick Reply: Does anyone use anti-seize on their wheel bolts?
