997 Turbo Forum 2005-2012
Fidelity Platinum Warranty Denial - Front axle
Old 05-26-2017, 10:21 PM
HellaHashTags
HellaHashTags's Avatar
Default Fidelity Platinum Warranty Denial - Front axle
My local dealership is trying to work with my warranty company, Fidelity, on getting my front axle replaced. I felt vibrations through the steering at freeway speeds and discovered, on the lift, that the CV boot was torn (grease leaked out of the torn boot, likely causing the axle to fail and cause vibrations.)
The service advisor from my dealership called Fidelity and Fidelity denied coverage for the repair, citing that the axle failed due to the CV boot failure.
I'm at a loss for words - this is Fidelity Platinum coverage?! I've only heard good things about Fidelity before.
Does anybody have experience with a situation like this or have any advice?
Update: Porsche Burlingame (and service advisor Chris Yip) did a tremendous job getting things straightened out and covered with Fidelity. I can't recommend these guys enough. Correlation =/= causation and Fidelity eventually ended up doing the right thing and fully covered the repair.
Old 05-26-2017, 10:22 PM
alpha motoring
alpha motoring's Avatar
CV boots are under the exclusions
Old 05-26-2017, 10:31 PM
HellaHashTags
I did notice that CV boots are under the exclusions, but axles are not excluded. Fidelity is denying coverage on the whole repair.
I couldn't have known that the CV boot was damaged until the axle was affected and starting producing symptoms.
Just feels kinda disingenuous.
Old 05-26-2017, 10:52 PM
HellaHashTags
After more digging, the axle is explicitly listed as a covered part under Fidelity's Gold coverage (Gold coverage is inclusive to Platinum coverage), so now I feel even more confused and cheated!
Old 05-27-2017, 01:57 AM
IMI A
IMI A's Avatar
Feel your pain but front axle has defo failed due to torn CV boot. Thats why bi annual service schedule is a joke for a car as complicated as a turbo. I've had two or three CV boots in 10 yrs of ownership from new caught early. If they hadn't been done large repair bill. You could try simply removing the front drive shaft and going rwd. a few guys have tried this and the diff noise vibration goes away and they have rwd to boot!
Old 05-27-2017, 03:04 AM
jcnesq
Miserable Old Bastard
jcnesq's Avatar
A buddy who bought Fidelity on my reco for his '06 C4, recently had an issue with the rear axle. They jacked him around, i think it was bolt failure or something as their excuse, don't remember the full story nor the ultimate outcome, but from what I recall, their denial was BS. But at the end of the day, all I can say is I think Fidelity plays every game in the book to avoid liability.
Old 05-27-2017, 12:32 PM
Catorce
Catorce's Avatar
Tell me more about the vibrations you were experiencing.
Old 05-27-2017, 06:20 PM
bgrpph
bgrpph's Avatar
I've had fidelity platinum on 3 porsche over the yrs- & believe they have been fair- I know they have clause which exludes "wear items" when car is over 50k miles. so that always has worried me but my '07 997 TT only has 32k miles currently.
they just recently covered front motor mount, new steering rack (was leaking) & secondary air combi valve on wifes 07 Boxster S with 77k miles->$3k coverage. (they wouldn't cover lower thrust arms, strut mount bearings). Fidelity also covered several minor issues with door handle/lock, window not dropping, etc.
On previous '02 911 C2 Fidelity covered leaking rear main seal, xtra key remote that stopped working, window issue, etc.
I've not had any claims on my '07 997 TT yet.
Old 05-27-2017, 11:58 PM
strato58
strato58's Avatar
It just seems like you are at their mercy. Having coverage then having to worry about them not covering something pretty much sucks.
Old 05-28-2017, 12:17 AM
CodeRed
CodeRed's Avatar
better to just self insure, if they dispute legitimate claims...glad i read this since i was thinking it prudent to sign up w them soon
Old 05-28-2017, 12:21 AM
eddielasvegas
eddielasvegas's Avatar
Exactly what I was thinking of doing too CodeRed so I think I'll pass.
And what's worse is they have your money, you have the problem (with car downtime) and yet you have to jump through hoops to get it covered. You may eventually get there, but you'll invest way more time that should be necessary.
Eddie
Old 05-28-2017, 01:21 AM
Catorce
Catorce's Avatar
Warranties other than those offered by the manufacturer are pretty much bogus.
Old 05-28-2017, 09:48 PM
TurnOne
TurnOne's Avatar
Since I have the same warranty this makes me want to check out the boots.
It makes sense they won't warranty it. Similar to having a failure and they find the scheduled maintenance that's pertinent wasn't performed.
Old 05-29-2017, 12:20 AM
gotgolf52
gotgolf52's Avatar
I have Fidelity, they paid for my charcoal canister for exhaust system, gas cap, tpms and that cost about the same price I paid for the entire warranty. Anything here on is bonus and peace of mind.
Old 05-29-2017, 03:04 AM
TT Surgeon
TT Surgeon's Avatar
I had preferred warranty inc, they covered an entire tranny rebuild, minimal hassle. This is the only Porsche I ever had an aftermarket warranty, only bc it was a long distance purchase.
Quick Reply: Fidelity Platinum Warranty Denial - Front axle
