1.8t Boxster
#46
Any particular reason why you won't entertain either selling the motor mount or performing this swap for customers? Just curious, as I'm really considering this and would much rather drop the car off with a shop who's done it before than pay for someone else to learn the ins and outs
I find doing complete conversion jobs for other people to be very stressful. I've done plenty of conversions over the years (TDi engines into VW Rabbit trucks, Subaru and 1.8t engines into Vanagons). If I'm doing them for myself on one of my own cars, it's fine, I can take my time, there is no time limit or budget limit. All the ones I have done for a customer have been very stressful, very time consuming, and not very profitable. I've found I'm better off to just do regular service on later VW and Audi cars.
I'm happy to share what I have learned along the way and pictures of what I've had to fabricate to get there. If someone else wants to get into business doing these swaps or just selling parts, good for them, I think there could be a market for it.
Andrew-
#47
Andrew, I'm not likely to ever do this swap, but I do find it deeply satisfying to look at your pictures and read about the intriguing details that you've teased us with. Well done! I'm eager to learn what you've learned while doing these conversions both on Vanagons and on your Boxster. I'm subscribing just for the geek factor and to appreciate your artistry. Having done conversions in the past like adding overdrive to an MG Midget and converting a Saab 900 from automatic to 5-speed, I can appreciate the problem solving you had to go through to get these conversions finished. Thanks for sharing, and I'm eager to see more details that you may share so others can do this conversion.
Scott
Scott
Andrew-
alpinaturbo (07-17-2020)
#48
Andrew,
OK, you've got me mystified about making a A4 engine run backward in a Vanagon. Did you create a custom camshaft and Motronic program to get it to run backward? Did you move the CPS relative to its default location? Dark magick must be involved there, that's all I can think.
Scott
Scott
#49
Andrew,
Scott
Scott
The ECM doesn’t need any modifications, it doesn’t know what direction the engine is turning.
The cams are stock, this engine has separate intake and exhaust cams, I had to time them differently to make them work.
The toner ring that the crank position sensor reads from needs to be repositioned
The pistons were taken out and put in backwards.
The starter was fixed by combining it with another VW starter that turns the opposite direction.
The oil pump, water pump, and PS pump also needed to be dealt with.
Here’s a video if the very first start up of a 1.8t running CCW. I’ve put together about ten of these engines now. I have about 20k miles on that first engine.
here is the original build thread on TheSamba, it’s funny to go back and read it now seeing the comments from some guys.
https://www.thesamba.com/vw/forum/vi...+run+backwards
#50
[QUOTE = xoo00oox; 15939078] У меня есть Boxster 99 года выпуска, который был 2,5, теперь с двигателем VW / Audi 1,8 т мощностью 200 л.с. Я купил эту машину в прекрасной форме, проехав всего 80 км и разбитую 2,5 из-за отказа IMS. Зная, что 5-ступенчатая трансмиссия в этом автомобиле трансмиссии 2wd VW Passat или Audi A4, я решил, возможно, двигатель от одной из этих машин. Я поставил все на место, и теперь на пробеге чуть больше тысячи миль. Автомобиль отлично подходит для вождения с турбонаддувом 4cy, и я получаю около 30 миль на галлон во время круиза. 1.8t примерно на 160 фунтов легче, чем стандартный 6-цилиндровый двигатель, и намного проще в обслуживании, и намного дешевле купить. Стандартные датчики подключены и работают нормально, также как и ABS и круиз.
Если кому-то нужны подробности, дайте мне знать,
Андрей-
[/ QUOTE]
hello namesake, I have a 2002 2.7 porsche boxster with a faulty engine. I want to make a 1.8t swap. I live in Belarus and I ask for your help in information. With respect. Andrey
Андрей-
[/ QUOTE]
#51
Hello again to all that are subscribed to this thread.
I have made a few more videos since my initial post. Here is the latest:
I have short blocked the motor and will be providing an update soon.
Right now I am hung up on the turbo to use for this setup. Currently considering the GT28.
Also, a challenge that I know I will run into is cooling the charged air without a front-mounted intercooler being in the picture.
Looking to utilize a custom water to air intercooler.
pilot4fn (10-15-2020)
#52
Hello there Andrew
Great thread and I love your ingenuity. Would this conversion work for a Tiptronic? What extra problems would you envisage? The Tip has it's own ECU, which AFAIK does not feed into the DME.
Many thanks
Berni
Many thanks
Berni
Reese303 (10-21-2020)
#55
#56
Agree on the 28RS. I had a slew of turbos on my 1.8T Audi (K03/stock, K04, GT28RS, GT3071R, Comp CT3 specifically). The disco potato 28RS was the right mix of spool and power. The bigger turbos made better dunno graphs but from a daily usable and on track (road course) perspective... They didn't compare.
#58
Getting close ladies and gentlemen on dropping the Boxster 2.5L motor and swapping in the built 1.8T. This video is an update of the additional parts that were added and what is left to be done. I am looking to drop the motor in mid-January. I have adjusted my horsepower goal to 450HP at the crank.
Here is a link to the latest video:
Let me know if you have any questions.
The following 2 users liked this post by Reese303:
Lincoln Peters (04-25-2021),
Radman73 (12-28-2020)
#59
I have a couple questions, what engine block did you use? I know any 1.8t will fit but my understanding is that the manifolds are diffent between the longitudinal and transverse set ups. Im wondering because you where able to use the Boxster Catt for your exhaust. Also what did you do for fueling. Did you have to fab something up to make it fit the intake manifold? Which intake manifold did you use?
#60
This is a wired thread to stumble upon. I feel very at home I had no idea about the use of the 1.8t in a boxster.
I own a modified 1.8t (ATW) in my A4 with 215K miles on it (@~250hp). i've done 3 timing belt changes on it and it keeps on ticking. here is a pic of the last one i did in 2019:
my other car is a '20 718 Cayman. another turbo 4
