Boxster & Boxster S (986) Forum 1996-2004
Boxster Odometer Problem
Old 07-16-2004, 11:35 AM
bsocha
3rd Gear
bsocha's Avatar
Default Boxster Odometer Problem
I recently changed the battery in my '99 Boxster. After the gauges synched back up the odometer showed 999,999 (it was in kilometers). I switched it back to miles and now it shows 599,999. Everything else is fine. When I drive the trip odometer is fine but the odometer never moves.
I tried unhooking the battery and hooking it back up hoping things would synch but its still the same problem. I talked to a local porsche mechanic who had no idea what would cause this problem. I also talked to the dealer who said the same thing but would be more than happy to take a look at it for me.
Has anyone ever seen this or know what could cause it?
Old 07-16-2004, 01:54 PM
Tool Pants
Tool Pants's Avatar
At our work on cars days over the years we have disconnect the batteries in many cars and this has never happened. But once in a while on the message boards I see reports such as yours.
Try this. Disconnect the negative cable with the key in the ignition. Turn key to position 1 and then turn key to off position. Then hook up negative cable.
Al Allen (05-02-2022)
Old 07-16-2004, 02:34 PM
bsocha
3rd Gear
bsocha's Avatar
That worked!! Thanks a ton!!
Nive (05-01-2022)
Old 07-20-2004, 08:47 AM
Q
Q's Avatar
Tool Pants,
Is there anything you don't know ?? !!
Old 07-20-2004, 04:52 PM
Tool Pants
Tool Pants's Avatar
Originally posted by Q
Tool Pants,
Yes. Why in the world does this fix the problem with the display.
Old 07-23-2004, 07:21 PM
Q
Q's Avatar
LOL
Old 08-26-2010, 01:14 PM
ohdavey6286
ohdavey6286's Avatar
Sorry to bring up this old thread. I had the same issue with my car and tried this fix with no real effect on my car. Does anyone else have a fix?
Old 08-29-2010, 12:00 AM
Macster
Macster's Avatar
How long did you leave the key in the #1 position after you disconnected the negative battery lead?
You may not have left the key in the #1 position long enough. Unless you think you did try it again and this time leave it in the #1 position longer, and press the brake pedal and hold the pedal for a moment.
You want to fully bleed away any power that is allowing the instrument cluster controller to remember the wrong valve.
Sincerely,
Macster.
Old 06-15-2015, 10:29 AM
Edgarz
2nd Gear
Edgarz's Avatar
Default 1999 Posrche 911 C4
I thought it would be a good idea to bring this thread back to life and share my experience.
This just happened to me after I picked up my car from the mechanic who had been working on the brake switch, after a while I discovered that the radio, trip meter and speedometer have been completely reset to Km and it showed 999,999, I tried taking it back but they were closed for the weekend and the things I was reading on line were not to hopeful until I found this thread and IT WORKED.
Old 11-25-2015, 03:18 PM
Juan Faro
Juan Faro's Avatar
Default 97 Boxster
I have tried the disconnect negative post cure multiple times and even left it overnight, still the same dreaded 599999. even tried disconnecting both posts, still nothing. anybody have an idea what to try next?
Old 08-19-2016, 02:03 PM
rickand
rickand's Avatar
Default 99 Boxster - worked perfectly for me
(As long as I turned to position 1 not 2 &#128527
Even went back to original mileage 44100 - I was afraid it was lost.
Lots of maintenance recently, not sure what caused it but wonderful to see it fixed. Thanks!!
PS: also fixed metric gauge displays as well
Old 05-01-2022, 03:07 PM
Nive
Nive's Avatar
Default Odometer
That worked for me also, thank you
Old 08-14-2022, 09:24 PM
AMGarcia
AMGarcia's Avatar
Default Confirmed Solution! 2022
I just attempted this fix on a 1999 Boxster with the the odometer showing 99999, and it corrected the odometer! 👏👏👏
Quick Reply: Boxster Odometer Problem
