Boxster & Boxster S (986) Forum 1996-2004
Hardtop install DIY??
Old 03-14-2005, 10:44 PM
Fletcher
Fletcher's Avatar
Smile Hardtop install DIY??
Anyone here done it themselves? Any pics or other diy links
Old 03-15-2005, 01:44 AM
ar38070
ar38070's Avatar
See www.renntech.org and do a search. It is not hard to do.
Old 03-15-2005, 02:36 AM
Moogle
Moogle's Avatar
basically you need to install the spinlocks, not hard.
Old 03-15-2005, 04:25 AM
Irishdriver
Irishdriver's Avatar
Yes I did it - the golden rule is don't drop the screws.
I have photos if you want to see them..?
Old 03-15-2005, 04:30 AM
PaulStewart
PaulStewart's Avatar
And adjust it to fit properly.
Old 03-15-2005, 12:20 PM
Doug&Julie
Doug&Julie's Avatar
I did it on my car and it took HOURS, plus two trips to my mechanic to "fix" what I coudn't do.
I did it on my brother's car and it took 15 minutes.
A lot may depend on your car. But do a search here and there should be a couple of threads on this subject. Mine will be one of them!
Good luck!
Old 03-15-2005, 04:51 PM
Irishdriver
OK here we go...
I'll try to get these in the right order and no doubt we'll get additional advice along the way....
First find the receivers for the roof these are in the B posts... pic 1
then pull the plastic caps out of the holes......pic 2
Old 03-15-2005, 04:54 PM
Irishdriver
Now get the necessary bits from your friendly Porsche center.....pic 3
and drop the cylindrical part into the hole....pic 4 Making sure you have right and left correct.
Old 03-15-2005, 04:58 PM
Irishdriver
Now the fun part ...find some way to hold the screw to the allen key as I don't know if you will ever see the screw again if you drop it. Some recommend pushing the end of the screw through a plastic bag - I went for a piece of tank tape.....pic 5
and start looking for the hole.....here is the passenger side (easier to take a pic)...pic 6
Old 03-15-2005, 05:02 PM
Irishdriver
Of course the screw should go in sweet but it's best to locate it turn it in the wrong direction until you feel it is properly centered and then wind it in. It doesn't hurt to check if the threads of the hole are clean first !! pic 7
Old 03-15-2005, 05:06 PM
Irishdriver
now before you do anything else ..go and find the socket fot the rear window heater. It's on the driver side just behind the roof mounting point...pic 8
You have to lift to cover to see the connection...pic 9
Old 03-15-2005, 05:16 PM
Irishdriver
this is the exciting part....two people should lift the roof into place. Don't try it on your own as it's not heavy but it's akward and you will scratch something.
the front of the roof locates on the top of the screen and you let the back sit into place gently.
Now the pins on either side of the roof (pic 10) should be aligned with the receivers you've just fitted and by turning the red levers you should pull the roof nicely into place.
....adjustment...Hmmmm. If the roof doesn't sit nicely then you need to loosen the three allen bolts on each side holding the red levers to the roof. These are in slotted holes so you can adjust the roof with respect to the levers. We could get formal but the practical way to do this is to get a friend to push thr roof down into place an then tighten the allen bolts.
..get out have a look.....swear at your friend for not holding the roof in the right place.....apologise to your friend and ask him (her) to try again. You'll soon get it right. Pic 11 & 12.
Old 03-15-2005, 08:00 PM
Fletcher
Fletcher's Avatar
Thank you! Great work!
Did you pull off the carpet panels to get to the allen screws?
Old 03-16-2005, 11:15 AM
ar38070
ar38070's Avatar
When I did mine I ended up pulling off the carpet pieces (after having dropped the screws 2 or 3 times and having to fish them out). It gives you a straighter shot at the screw holes and makes starting the screws straight a lot easier. Takes 10 minutes longer but you easily make this up if it prevents you from dropping a screw.
Old 03-16-2005, 11:17 AM
Doug&Julie
Doug&Julie's Avatar
Ditto. And I think it makes it less likely to drop the screw. (one less thing to bang it on)
Quick Reply: Hardtop install DIY??
