Tire Pressure MPSC?
Ironman 140.6
I do. I have run them at Road America and Blackhawk. I find they work pretty well with the fronts at 34-35 and the rears 37-38 (hot temps).
Good luck!
Good luck!
Still plays with cars.
On my GT3 34 hot all around is near optimum. Some like 32F and 34 R. Several of us with GT3's on Cups observe that the window of optimal pressure is quite small on the Cups on our cars. We can feel a difference at 35 hot and the car is slidely at 36 hot. Ray, try a little less pressure in back and let us know if you see an improvement. Note, my pressures are based on a GT3 with 2.5 negative camber. They seem to work for cars with neg 1.5 equally well. Outside that range, things may be different.
I Have found that my car is best balanced at slaloms if the pressures front and rear are the same. A friend with a boxster S and trick suspension has come to the same conclusion....
Don't know if it is the same for track work.
Autocross needs higher cold pressures because you don't heat the tires as much as you would in a half hour session on a track.
Lifetime Member
Lifetime Member
I found them to be very good in the 33-35 range and they began to slide all over at 36 (this is on the 2550 pound SC). Although they were very linear on the way into the pressure window, the over pressure was nearly dramatic and they were significantly slower when going out the top of the window.
