Boxster & Boxster S (986) Forum 1996-2004
Nasty squeal/screech at startup
Old 10-20-2006, 08:02 PM
oversteerdawg
oversteerdawg's Avatar
Default Nasty squeal/screech at startup
Hey guys. My 6 speed '01 986S w/ 47k makes a nasty squeal/screech for about a half second on cold start. It just started a couple of days ago. It does not happen when warm. I'm thinking (hoping) it's a belt, but I'm not sure. A/C, power steering, water temp are all fine and the car runs great. Anyone experience something similar? Thanks in advance
Old 10-20-2006, 09:59 PM
SD Porsche Fan
Cast Iron Man
SD Porsche Fan's Avatar
Altenator belts have a lot of drag at start up. Power steerign would be my next guess.
Old 10-21-2006, 12:37 AM
blinkwatt
blinkwatt's Avatar
Every once and awhile my 99' Boxster would do that. The cure? It was time to replace the serpentine belt. Simple D.I.Y.
Remember there is one belt for ALOT of things on the car so its a good idea to change it before you hit the 60k maintainence mark.
Old 10-21-2006, 01:33 AM
deliriousga
deliriousga's Avatar
If it's not the belt, check the oil filler tube and see if it's squished when the engine is started. If so, it probably has a hole worn in it because the air/oil separator is going kaput and the vacuum is causing the squeal. Both have to be replaced if that's the case.
Old 10-27-2006, 04:27 PM
autobahnNY
autobahnNY's Avatar
I had the exact same problem. Dealer change the starter. No problem since then..
Quick Reply: Nasty squeal/screech at startup
