Boxster & Boxster S (986) Forum 1996-2004
Help! Locked out (again)
Old 02-19-2007, 09:28 PM
catalogguy
catalogguy's Avatar
Default Help! Locked out (again)
Car is locked, battery is dead (MY2000 S). You know the tune. In anticipation of receiving my new battery maintainer, I decided to hot wire my car's electric system to unlock the hood and thereby enable access to the battery. I devised a new cigarette lighter plug to lighter plug and even added clamps. I plugged in the car and then to my trickle charger. The alarm meekly beeped several itmes while it flashed the lights (a good sign) and then went dead. I believe that by having the charger set to 10 amps I likely overloaded the cigarette lighter circuit and blew the fuse. Here comes the fun part. I did not find a blown fuse, but seem to have misplaced my little piece of paper that shows which fuse is for which circuit. (Maybe there is a diagram in the FM which is locked inside the rear trunk).
1. Can anyone look up which fuse goes to the cigarette lighter? It would be super if someone could scan the page and post or email it :-)
2. How else can I feed in power? I could stick wires into the fuse block, but which places?
Thank you!
Old 02-19-2007, 11:34 PM
PTEC
PTEC's Avatar
The fuse for the cig lighter is d5 I believe. This is from memory. If that fuse is good and you still arent getting power make sure you have a good ground. If you still cant get anything, have fun finding the emergency release.
Old 02-20-2007, 12:46 AM
99firehawk
99firehawk's Avatar
back feeding any of the accessory points should provide enough power to open the trunk do not start the car that way or even turn the ign on as you will blow many fuses
Old 02-20-2007, 06:46 AM
stumpjumper
stumpjumper's Avatar
maybe this varies by year, but my 2002 has a block in the fuse box to attach a positive battery terminal clamp, and instructions in the manual saying to attatch the negative to the door lock latch for exactly this problem
Old 02-20-2007, 08:41 AM
99firehawk
99firehawk's Avatar
early cars do not have the jump point in the fuse box
Old 02-21-2007, 01:44 AM
ajauch
ajauch's Avatar
Yes, the jump point in my '04 was a pleasant suprise when I upgraded from my '00.
Old 02-21-2007, 12:08 PM
catalogguy
catalogguy's Avatar
Default Thanks!
Old 03-03-2007, 01:49 AM
black986S
black986S's Avatar
Smile
You guys are going about this the wrong way. There is a special trick to getting into the bonnet of the Boxster. First pry your hands above the LF wheel, and you will feel a plastic flap on top to protect the shock absorber. Peel back this plastic flap, and you will feel a cable. Pull on the cable, and the bonnet will open. If the battery is not completely dead the alarm will start sounding. Believe it or not this actually works.
.02$
Old 03-03-2007, 01:54 PM
99firehawk
99firehawk's Avatar
crawl around on the ground and stick you hand into the griey well well over the greasy tire looking for a releae cable thats harder to find then a wmd .
or back feed the fuel box and release it electonicly without getting dirty hmmmmmmmmmmmmm
Old 03-04-2007, 07:41 PM
black986S
black986S's Avatar
It's an easy trick, I can open a boxster bonnet in under 15 seconds, and if the car is not lowered, you won't get dirty. Give it a shot, it works.
Old 03-04-2007, 09:28 PM
99firehawk
99firehawk's Avatar
ive done it, its never 15 seconds.
Old 03-11-2007, 12:53 PM
designman
designman's Avatar
Why are you guys calling it a "jump point"? The manual says you can't start the car this way. Isn't that positive terminal in the fuse box just to open the lids? How do you open the lids on the earlier models, from the wheel well as described above?
Old 03-11-2007, 06:55 PM
black986S
black986S's Avatar
It's actually quite simple. In LF wheel well, feel directly above the tire, and you will feel a plastic flap. Pry plastic flap down (don't worry it's very soft, and you won't damage it) and feel behind flap for a cord. Pull slightly on cord, and bonnet will pop right open.
Old 03-11-2007, 11:19 PM
99firehawk
99firehawk's Avatar
dont start the car that way youll blow lots of fuses that way. only use it to pop the trunk
backfeeding through the cigar lighter or the fuse box is easier then trying to find the trunk release on older cars
Old 03-12-2007, 08:49 AM
stumpjumper
you can't start the car this way, but you can power the electric trunk opener to replace your dead battery
Quick Reply: Help! Locked out (again)
