Replacing CDR23 HU with Alpine - wiring question
I'm replacing my CDR23 (and amp) with an Alpine 9885 HU, and I'm told that some late model VW wiring harness adapters may work on a Boxster.
Anybody out there have any idea which VW models/years might be candidates to be used on a MY03 Base Boxster with a CDR23? Not finding too may off the shelf wiring adapters for Porsches at the Crutchfields or Woofersetc of the world
I used a harness off a same year VW (all the same harness) and it worked perfectly... well it worked, some of the wires did nothing if memory serves me corectly. I think that there was also a switch up on 2 of them, so it may take a wee bit of experimenting. I would take the old headunit into a shop and compare the back of it to the harness they sell, just to check. I ripped out a CDR-220, so it might be different? You will also need an antenna converter to switch from the odd euroupean antenna to the standard US antenna.
BTW....Damn, does this thing ever sound good with this Alpine 9885 and 100w per channel power pumping through there! Volume and clarity with the top down are certainly not a problem any more...!
BTW everyone, I would highly recommend this Alpine CDA-9885 unit to anyone without hesitation.
It mounts in the Porsche console nicely, without ugly fill plates being needed, and looks like it belongs there. It doesn't have a blingy appearance as many of the units available today do. The sound is clear and full. The 4v outputs of the 9885 make a noticable difference in the clarity over the 9883 - if you are feeding an external amp, otherwise the 9883 is a great unit as well.
lucky to have time to play
I'm glad to hear you are doing so many cool things to your boxster, I wish I had the time to work on mods on mine, Just a little more time to drive it would be nice. Keep up the good work, enjoy and keep inspiring us to do the same.
Still trying to find the time to upgrade the speakers like you did
