Factory Stereo Q's
Factory Stereo Q's
Looks like I'll be getting back into the Porsche game. Looking at 2001 ~ 03 Boxster S's and have a question.
A lot of the lisitngs I see list a cassette player. Is this right? Not a CD on this quality car?
Thanks in advance...........
CD/cassette
I believe the 220 head unit is a CD and the earlier ones came with a 210 (this is prior to the conversion to fibre optics) which was cassette.
I _think_ that's right. Having just bought a 2001 last week, I'm still learning.
cheers,
S.
cheers,
S.
presonally I would not go with the factory CD player, but instead use an aftermarket. I pulled my CDR220 out because I did not like it. replaced the headunit and it made a big difference in sound quality. still not good, but more like marginally acceptable; with the top down can't hear much on the interstate anyway...
Replacing the HU improves the sound, yes, but the stock paper cone drivers are crap too, and the M490 amp is both poor quality and underpowered for a cabrio. If you don't replace the drivers and the HU, at a minimum, don't expect much in the way of sound quality or volume with the top down.
For under $1000 you can replace the HU, Amp and speakers if you shop around and watch places like Crutchfield.com and woofersetc.com for deals. The sound quality will be hugely improved, and you can hear your tunes crisp and clear even while tooling down I80 at 95 mph.
Polk Audio, Infinity, or MB Quart drivers to replace the crap paper coned stock speakers are reasonably priced, easy to install, and a HUGE improvement as a starter. Next dump the Becker head unit for a good Alpine or Nakamichi unit (with pre-outs) that has the features you want and the sound gets MUCH better again. Not necessary, but recommended, is adding the PNP rear shelf speaker kit. With it, the sound stage opens up to fill the whole car. Finally, add a couple of Profile, Alpine, or Infinity amps, or a single 5 or 6 channel amp, at 70 watts per channel or better, and that will take care of the top down issues.
Icing on the cake is to add a subwoofer. Not much room in the Boxster for 12" boomer cabinets if you don't want to give up the rear boot, but you'd be suprised at the bass you get out of a 6" Bazooka tube or Kenwood's KSC-SW1, both of which can be found for under $150 over the internet, and both of which can be mounted behind the passenger seat easily and without giving up much seat adjustment.
Good luck with your new ride.
first986NJ, not trying to steal the thread, but I got a pair of MB Quart speakers to replace the dash speakers and after looking at it, it didn't appear that easy to do. Any suggestions?
I think you'll likely need vfxbox's adapters unless you want to bugger the stock speaker mounts, plus a VW wiring harness adapter from Crutchfield. With these two additions, I'd be surprised if you couldn't get the MB Quarts into the stock mounting area. That said, my install is this coming weekend..
2) get your hands on a set of vfxbox's adapters, or 3) get a set of grills that are similar and make your own mounts. 2 is the easiest, followed by 1. I think there are a set of Dynaudio 4" component speakers that have a grill that is similar in shape to the stock ones.
If you study the pics of vfxbox's adapter closely, you can probably figure out how they work and make a set out of 1/8" lexan or something similar.
Not that hard...but not effortless either....and worth the work...the stock drivers really suck.
the conversion to MOST (the fiber-optic connection between the headunit and amp) began in 2003 models.
The Factory HI-Fi set up in my 01 has the 6 CD changer in the front hood area, behind the face plate is the cassette player. Just used it for instructional tapes, not music. As much as I listen to music, will not even upgrade on next car.
Originally Posted by IXLOR8
How can you put a CD Changer on a CDR-210? It does not have RCA's or UNILINK connection found in the CDC-3.
if you don't have one, you can download it here (you'll need to register and login first) http://www.renntech.org/forums/index...s&showfile=543
