Boxster & Boxster S (986) Forum 1996-2004
broke my shifter today
Old 09-27-2008, 03:10 PM
judd944
judd944's Avatar
Default broke my shifter today
1st to 2nd shift pulling out into traffic. car stayed in 2nd, shifter just flops from front to back. 3 hour wait to get towed. this happened at 12 today. I will be removing the center console tonight.
Old 09-27-2008, 10:08 PM
stumpjumper
stumpjumper's Avatar
if you're lucky, the little threaded connector just came loose, my dealer actually gave my car back to me like that once... oops
Old 09-27-2008, 11:42 PM
judd944
judd944's Avatar
I am not lucky. the shifter cable is broken. I am going to check with suncoast to see the price of this sucker.
Old 09-28-2008, 05:55 PM
stumpjumper
well since you have it apart take the opportunity and snag a b&m shifter from them too (or a 997 shifter box)
give yourself a present for all the pain and suffering
Old 09-28-2008, 11:03 PM
judd944
judd944's Avatar
I think I am going to stay stock. most of the people posting about short shifter say they are going back to stock. any leads on the cable kit?
Old 09-29-2008, 09:47 AM
stumpjumper
you couldn't convince me to take the b&m out of my car, I love it... even my wife thinks it's better than stock
I've got no idea about the cables though, not sure how tough it will be to run them either
Old 09-29-2008, 11:37 PM
judd944
judd944's Avatar
found this on rennlist. it is on a 99 996 but I am guessing it will be similar on the Boxster. The cables are 271 plus tax from the local Porsche dealer.
Old 09-30-2008, 12:53 AM
Tool Pants
Tool Pants's Avatar
Don't know what you found but 996 shift cables are a lot shorter than 986.
Old 09-30-2008, 12:45 PM
First986NJ
First986NJ's Avatar
Ditto...twice......
....although first time she drove it, she thought at first that it wasn't going into gear because the throw was so much shorter.....
Old 10-01-2008, 09:20 PM
Ryan C
Ryan C's Avatar
I was never a fan of those short shifters. Is it worth it if you grab the wrong gear? That's kinda how I look at it.
To replace the cable is very similar to the 996 but the cables go over the engine, it may be a little tough fishing it out and into the engine bay. There is a power wire there and a little gaurd to protect it from the belt. You should disconnect your battery when you do it.
Old 10-02-2008, 09:39 AM
David A
David A's Avatar
I think you can upgrade to a 997 shifter for under $200. Call steve at Suncoast Porsche. http://e-partssales.com/Merchant2/me...tegory_Code=PO
Old 10-02-2008, 02:12 PM
judd944
judd944's Avatar
I got the cables in at the local dealer today. I will be starting the replacement tomorrow. I will take photos and maybe even make a video to put on youtube of the process.
The part was 271 plus tax with the PCA discount.
Old 10-03-2008, 05:07 PM
judd944
judd944's Avatar
I got finished about 1 today. I then changed the oil and took it for a test drive. everything feels great. The cable was broken at the point where it transitions to a metal shaft ( near the transmission)
Quick Reply: broke my shifter today
