Boxster & Boxster S (986) Forum 1996-2004
Debadging
Old 08-20-2009, 11:43 PM
Larry L
Larry L's Avatar
Default Debadging
I'm planning to debadge my deck lid this weekend, but the car is silver. How does the silver hold up on the Boxsters? Will the paint under the script be a completely different hue?
Old 08-21-2009, 08:50 AM
mts
mts's Avatar
Depends. I debadged by 2004 SE and the paint under it matched exactly. Of course it only has 19k miles and is garage kept both at home and when I drive it to work. My friend debadged his 1999 car with 95k miles and the paint underneath was clearly a different hue. However, it's only something you can see from a couple feet away and it turned out kind of cool in my opinion......it's sort of a light "shadow" outline of "Boxster". I like it.
Old 08-21-2009, 03:25 PM
Tierce
Tierce's Avatar
I debadged mine after it had 75k or so, and being black, it isn't perfect but you can still see it from certain angles. but again, from only a few feet away.
Old 08-21-2009, 04:26 PM
Larry L
Larry L's Avatar
I have a handful of paint care products on hand. I can make it less noticeable if need be, but I'm hoping it won't stick out like a sore thumb.
My new glass-window top showed up this afternoon. It's going to be a busy weekend. I may have to do some of this stuff next week. Got a pair of 6.5" Polk Audio db speakers on the way too. I'm going to try to fit them into the factory locations.
Old 08-21-2009, 07:26 PM
Larry L
Larry L's Avatar
The roofers left, and it stopped raining for 18 minutes, so I knocked out the badge while i had a chance.
Pic #1: The offending badge & dental floss.
Pic #2: The badge after being liberally hosed with non-ammonia glass cleaner. Floss started underneath the right side of the script.
Pic #3: Floss halfway through the badge, using plenty of glass cleaner and a gentle sawing motion. Floss is kept flat to the surface of the trunk.
Pic #4: Detached badge and two-sided tape that held it.
Pic #5: Using nylon stick with chisel end to remove two-sided tape. (Not: NOT recommended for 100 point paint.)
Old 08-21-2009, 07:34 PM
Larry L
Larry L's Avatar
Pic #6: After first pass with nylon chisel.
Pic #7: After second pass with nylon chisel.
Pic #8: Ghost of badge apparent after removing all tape & glue residue.
Pic #9: Trunk lid after a gentle rubdown with Mequiar's fine cut cleaner, quickie wash job, and quickie wax with a good quality protective wax.
Old 08-26-2009, 11:17 AM
ATL986
ATL986's Avatar
looks pretty darn good. well done.
Old 08-26-2009, 05:51 PM
gerrygug
gerrygug's Avatar
Looks like I will be doing the same this weekend. Thanks for the nice write-up and pictures.
Old 08-26-2009, 09:38 PM
schwank
Herr Unmöglich
schwank's Avatar
Yeah, very happy I got mine debadged... looks great.
Old 08-31-2009, 09:41 AM
stumpjumper
stumpjumper's Avatar
I debadged mine because the S was falling off, I ended up rebadging it because the contrasting script broke up the outline a bit and I ended up missing that
Old 09-01-2009, 12:07 PM
Larry L
Larry L's Avatar
It did look a bit naked at first, but I've already gotten past it.
Quick Reply: Debadging
