Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Water Cooled Technical Discussion Areas > Boxster & Boxster S (986) Forum
Sign in using an external account
Register Forgot Password?
Search
Thread Tools Search this Thread
Old 09-01-2010, 10:40 AM   #1
espooner
New User
Default How to clean brake rotors?
On my '02 Boxster S, I have Pagid Orange pads for the track. After 3 days at Watkins Glen, there was a severe pulsation on braking, which appears to be due to pad build-up on the rotors, according to knowledgeable people at the track. There was a fair amount of pad material plugging the cross-drilled holes, which I drilled out, so I think this theory is quite probable.
My question is how do I best clean the rotors? One friend suggested brake cleaning fluid and a Scotch-Brite pad and lots of elbow grease. What has worked for others? How do you clean the INSIDE surface of the rotor (toward the centerline of the car)? I'm a fairly proficient DIY mechanic, but don't want to pull the rotors off, again, just for cleaning.
Any helpful hints would be appreciated. Thanks in advance.
espooner is offline   Reply With Quote
Old 09-01-2010, 11:13 AM   #2
mavthenav
mavthenav's Avatar
The pad material is a symptom of being on the brake and acellerator at the same time, once these are clogged you have no place for the compressed air between the pads and the rotors to escape and thus your pulsating. Between each session you should use a air hose to blow most of it out, what doesn't blow out poke with a screwdriver and it will pop out.
Sean
2003 996 Targa - Seal Grey
1983 SC convertible - Champagne
2010 Landrover LR4 - White
Race spec Go-Kart, time to get the kids in the groove
Always on the lookout for a new girl for the stable.
mavthenav is offline   Reply With Quote
Old 09-01-2010, 11:20 AM   #3
RollingArt
RollingArt's Avatar
Brake clean and scotch-brite here also. I would do this regularly on my road racing motos. Works good.
Phil
RollingArt is offline   Reply With Quote
Old 09-01-2010, 09:45 PM   #4
Renn 951
Renn 951's Avatar
Quote:
THAT is total nonsense...
Brake clean and scotch-bright are the first things to try as others have stated. Pagids are great pads except they can be very sensitive to proper break-in procedures. And trying to do their recommended break-in procedure on the street can get you arrested, and trying to do it on the track will tick off a lot of the other people in your run group. And if you don't do it they way the recommend it, you can end up with pad deposits like you've experienced.
Pagid Yellows aren't as sensitive as some of their others to break-in and also won't wear down the expensive cross-drilled rotors as fast as some other compounds. You might consider switching to the Yellows for your next track event.
02 996TT X50
04 Cayenne Turbo
88 944 Turbo
06 BMW 530xiT
Renn 951 is offline   Reply With Quote
Old 09-04-2010, 06:41 PM   #5
Macster
I believe you misheard or misunderstood what you were told. There is pad build upon the rotors but cleaning the rotors will not remove the build up.
The very few times -- thankfully -- I've experienced this is with new pads or new pads and rotors present and prior to performing a proper brake bed in operation and bringing the car to an emergency stop and leaving the pads (now very hot) in contact with the (very hot) rotors.
(Once this happened with properly bedding brakes when I washed my car and left it sit with wet brake hardware. Rust built up of course which under normal circumstances will be removed with no problems when the brakes are used. However, I had to bring the car to an emergency stop from high speed before I used the brakes enough to remove the rust and afterwards the pulsing was present. Not severe, thankfully, but present nonetheless. I always drive a car after I wash it to use the brakes enough to comletely dry the brake hardware.)
Anyhow, an emergency stop from speed results in the natural deposition and removable of pad material to the rotor being interrupted and some pad material remains on the rotor.
When this happens the friction characteristic of the rotor is changed to have less or more friction where the pad material was deposited and remained on the rotor.
In the several cases where this has happened I tried to perform a brake pad bed in operation to undo this condition but was not entirely successful. I believe in one case the condition's symptom was reduced but not eliminated. I learned to live with very light pulsing.
The only surefire cure/solution I know of is to resurface the rotors -- if they have the thickness to allow this. The resurfacing doesn't have to remove much material, just a skin cut in machining parlance.
Once the rotors are recut and for new pads or new rotors and new pads the brakes must be subjected to a brake bedding in process to help ensure this uneven deposition of brake pad material does not happen.
Also, at the track it is very important to take a cool down lap to give the brakes time to shed the considerable heat they accumulate. Failure to do this can result in uneven deposition of the brake pad material when the car is brought to a halt.
You can try to rinse/clean the brake hardware and of course make sure the holes in the rotors are free of any debris but I would be very surprised if this eliminated the pulsing.
Rotor resurfacing I believe is your only surefire course of action.
Sincerely,
Macster.
Macster is offline   Reply With Quote
Old 09-05-2010, 01:30 PM   #6
Craig - RennStore.com
Basic Sponsor
Craig - RennStore.com's Avatar
Pagid Yellows. Oranges won't cut it for hard track use and aren't made for it anyways.
Macster has good advice -
-Craig
425-765-1090, www.Rennstore.com -- assistance for selections welcomed
PAGID brake pads - Daytona winners & every podium position
GiroDisc F&R SLOTTED rotor upgrades (e-mail me) / Pad spreaders AVAIL. - e-mail
*10* yrs of business
<<My 930 12 yrs DE events, 514HP 930 track car
E-mail for any questions: Rennstore@Comcast.net
Craig - RennStore.com is offline   Reply With Quote
Tags
bedding, blow, boxster, brake, brite, clean, cleaning, deposits, failure, pads, pulsation, pulse, remove, resurface, rotor, rotors, scotch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
