Boxster & Boxster S (986) Forum 1996-2004
DIY Oil Change
Old 03-30-2011, 06:26 PM
AutoAtlanta
Former Vendor
AutoAtlanta's Avatar
Default DIY Oil Change
I am fairly certain that if you are on this forum, you have a clue. Most people with a clue know how to change their oil. (I was reading Wayne's new book and it has a whole section dedicated to changing the oil).
Anyway, we have been asked more times than should be necessary!
http://www.autoatlanta.com/howto/1/
Old 03-31-2011, 04:53 PM
Macster
Macster's Avatar
Using just ramps the amount of oil drained is not affected by any substantial amount. The Boxster manual doesn't give a drain time, but my Turbo manual calls for a drain time of 20 minutes. The Boxster manual does say the oil change should be done with the engine at an operating temperature of between 70C and 90C.
Lubro Moly oils are not on PCNA's approved oils list.
The only Liqui Moly oils on PCNA's approved oils list are:
Leichtlauf High Tech SAE 5W-40 (valid to 06.02.2012)
Top Tec 4100 SAE 5W-40 (valid to 10.04.2011)
Nachfull-OI SAE 5W-40 (valid to 10.04.2011)
Pro-Engine M 400 SAE 5W-40 (valid to 10.04.2011)
All of the above oils have the WW classification which stands World Wide.
Also, the instructions call for too much oil. The Boxster does not require 10 quarts. Without the filter change the oil capacity is 7.75l or 2.04 gallons or 8.18 quarts. With a filter change this requires approx. another 1/2 quart of oil.
My Porsche tech contacts caution me against overfilling the engine with oil.
In fact, cold the oil level should be a segment or two below the full/max mark to allow for oil expansion when the engine/oil is hot.
Correction: 2.5l engine's oil capacity is 8.25l (with filter change) and 7.75l (without filter change). Both the 2.7l and 3.2l engines have an oil capacity of 8.75l (with filter change) and 8.5l (without filter change).
Sincerely,
Macster.
Old 04-01-2011, 10:14 AM
BostonDuce
BostonDuce's Avatar
From the '10 Boxster S manual:
"Oil change with filter approx. 1.98 US gal/7.5 litre".
BD
Old 06-10-2012, 05:21 PM
welles
welles's Avatar
I can confirm these points based on today's oil change of my '04 2.7. I backed it on to my ramps, and drained the oil from a hot engine. Drain time was under ten minutes. I replaced the filter (Purolator L25316) and added nine quarts to the sump. The Bentley manual states 8.75 liters (9.25 quarts). The dipstick read just shy of full, and the electronic gauge read full.
FYI, Castrol Syntec is now labeled as 'Castrol Edge with SPT', but retains its' Porsche A40 approved rating.
Quick Reply: DIY Oil Change
